Jan 20, 2004 - 10:44 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 25, '03 From cranston RI Currently Offline Reputation: 0 (0%) |
i have no f'ing clue when it comes to engines, so i have a few questions... could someone explain what the OD button does besides make the tach jump about 1k rpms? (told you i was stupid)... and will i actually notice a performace jump by adding a few bolt on up grades like a CAI and better muffler? thanks...
Jan 20, 2004 - 10:54 PM
Enthusiast ![]() ![]() ![]() Joined Nov 6, '03 From Campbellsville, Ky. Currently Offline Reputation: 0 (0%) |
OD is short for over drive, it is is designed to make your car get better gas mileage by shifting into a higher gear thus reducing engine speed, which inturn also helps wear and tear on your engine.You should keep the OD switch engaged on your car, that is why the light comes on when it is turned off. |
Jan 20, 2004 - 10:57 PM
i always do... i knew it stood for overdrive, just didnt know the exact mechanics of what it did..
Jan 21, 2004 - 1:24 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
Automatic transmission cars that don't have an OD button have it engaged already...the car shifts to fourth gear normally. When you turn the OD off on cars that have it selectable like the Celi, the tranny only shifts into 3 gears...that why when you're cruising and you turn it off the RPMs jump up...the tranny downshifted to third.
Jan 21, 2004 - 10:20 AM
so how about preformance boost with adding a muffler and CAI? will i notice anything?
Jan 21, 2004 - 12:05 PM
Just minimal...you'll feel it but it's not a huge gain. A CAI with full exhaust and muffler will make a difference...it's just not big for you to get impressed.
| Lo-Fi Version | Time is now: May 17th, 2026 - 12:02 PM |
