> Engine start Problems, camry 5sfe motor
post Mar 6, 2013 - 4:23 AM
HerosBlade
Joined Mar 22, '09
From Oahu, Hawaii
Aloha everyone from the state of Hawaii my mom's car has a problem 95 Toyota camry 5sfe 2.2L auto trans
The car cranks but wont turn over!
808joey and myself checked timing belt to see if its torn or slipping but its still good, change distributor, and yet no spark to the plugs, also car take OBD1 so we used a paper clip to see any sensors that r not working but the check engine light doesnt come on or flashs. I was wondering is that a good thing or not frown.gif ????
What I am going to do is to switch the ignition module for my 5sfe motor see from there any ideas or if anyone have that same problem??????
The New Kid on the Block
Replies (1 - 4)
post Mar 6, 2013 - 9:47 AM
blackliftback
Joined Mar 1, '12
From iowa
Try testing the spark plug wires.
post Mar 6, 2013 - 10:13 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
first off, cranking and turning over is the same thing. its not running.
so you say you are not getting any spark as you crank the engine? thats telling me the ignighter is bad or coil. can you tell if the injectors are firing? take out the plugs and see if they are wet. if they are not wet then im guessing that the cam position is not getting to the ECU.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 7, 2013 - 8:21 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Does the engine light illuminate when the key is on but the engine is not running? As in just put the key in 'run' but don't crank it.
post Mar 8, 2013 - 1:54 AM
HerosBlade
Joined Mar 22, '09
From Oahu, Hawaii
checked those items but none of those are working the am2 fuse was popping but couldnt figure not how or where the short is coming from going to take it to someone I know cause I think that is some where in the wiring.
Lo-Fi Version Time is now: August 28th, 2026 - 11:03 PM
