Mar 14, 2013 - 7:27 PM
Enthusiast ![]() Joined Nov 13, '12 From Sacramento Currently Offline Reputation: 0 (0%) |
Hi all 6gc members! I am currently having a little bit of trouble with my celica and I was hoping some members could help shed some light. So when I try to start it, it sounds like it catches. But it starts idling really low (approx 500 rpm) and then the car just shuts off. Right before the car dies, the engine oil symbol pops up in the dash. Would this be because of the lack of oil pressure or does it just go through the dash cycle upon shut off? Please note that this process is less than 5 seconds. However, this problem does not always happen. Sometimes it would start perfectly fine and run fine. This problem just comes and goes. Would it be a fuel system problem? Thank you in advance for any help.
Mar 15, 2013 - 12:06 AM
Enthusiast ![]() ![]() ![]() Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) |
If the car stalls/dies/shuts off for any reason besides you turning it off with the key the OIL/CEL lights come on. Or are you saying it oil pressure light comes on before it stalls out?
Have you tried giving it gas when you start it to see if it will keep running? This post has been edited by travisxcore: Mar 15, 2013 - 12:07 AM |
Mar 18, 2013 - 10:03 AM
The car does keep running if I give it a little gas right when I see the rpm's to drop. I was wondering if this problem could be due to the lack of fuel pressure?
| Lo-Fi Version | Time is now: August 26th, 2026 - 12:13 PM |
