> build your own CAI
post Mar 19, 2013 - 11:10 AM
found this on another forum
http://www.airaid.com/u-build-it_intake_systems.aspx
not bad..
Replies (1 - 8)
post Mar 19, 2013 - 11:43 AM
Box
Joined Feb 23, '12
From Warrior, AL
FREEEEEEEEEEE HATTTTTTT!!!!!!!! I'M SOLD!!!!!!!!
2001 Miata LS 5-speed
post Mar 19, 2013 - 1:56 PM
lol, i did not see that!!!!
post Mar 20, 2013 - 8:53 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
As I always say, 1 tig weld is cheaper than a silicon coupler and 2 hose clamps. people are always gonna DIY their pipework i guess, then realise after they could have had it done properly in the first place and have a beautiful custom engine bay, rather than a dinky backyard look
Mike W
269awhp / 273ft-lbs
post Mar 21, 2013 - 7:52 AM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (delusionz @ Mar 20, 2013 - 8:53 AM) *
I believe welding can come across intimidating to some, where turning a philips or flat head driver is less of a scare.
post Mar 21, 2013 - 11:25 AM
Box
Joined Feb 23, '12
From Warrior, AL
I was taught how to weld back in 10th grade, it's not hard at all. The main problem I foresee is with everything welded together, how much more of a pain it becomes to install and remove the ducting becomes. Unless you're doing a basic short ram you'll still need couplers anyway. I agree though, welded looks a lot more professional.
post Mar 21, 2013 - 11:44 AM
rave2n
Joined May 29, '09
QUOTE (Box @ Mar 21, 2013 - 12:25 PM) *
I was taught how to weld back in 10th grade.
Guess I should have taken that instead of woodworking....
I'm sure anyone can learn to weld something, and it not prove difficult, but I'm sure there are many differences between trained/experienced welds compared to someone like me throwing money away trying to learn. Just like how I'm very critical of soldering jobs, and wire connections. I've seen a million solder joints by many engineers that I would be ashamed of it they were mine.
So all in all, I would resort to the simplicity of a coupling instead of saving a few pennies on the dollar to weld it together. Though it does look much more sexy.
post Mar 21, 2013 - 12:22 PM
Box
Joined Feb 23, '12
From Warrior, AL
If you already have welding equipment might as well weld what you can. I think as long as you use black couplings it still looks good.
post Mar 23, 2013 - 8:08 PM
this is for the do it yourself Backyardigan. No one will buy a welder to make a CAI. If you have it great!!!. but if you dont, get your free hat!!!
Lo-Fi Version Time is now: July 11th, 2026 - 9:59 PM
