> Manual Transmission filler and drain nuts, Need help
post Mar 25, 2013 - 4:59 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
I have a st204 standard transmission. Planning on changing my fluid to Pennzoil synchromesh to see if it'll help out on the 3rd gear grind. Now I know that they're 24mm nuts and I have the wrench and socket for it. The only problem I have is trying to break them loose. Them nuts are just so skinny and flat and big that it's so easy to strip them. Also they're in a hard angle too. Anyone have any ideas or tricks?
- ILoveMySilly97   Manual Transmission filler and drain nuts   Mar 25, 2013 - 4:59 PM
- - Malek   I used a short 24mm 3/8drive socket on a 8in ratch...   Mar 25, 2013 - 7:48 PM
- - richee3   Funny, I just had to do this tonight. I have to us...   Mar 25, 2013 - 9:56 PM
- - ILoveMySilly97   Short? Short meaning the regular size right? Or is...   Mar 25, 2013 - 11:09 PM
- - Malek   hmm..you may want to try a 12 point socket if you ...   Mar 25, 2013 - 11:20 PM
- - ILoveMySilly97   Lol. I was using a 12 point socket too btw. With m...   Mar 25, 2013 - 11:29 PM
- - Syaoran   When you manage to take it out, get a M18x1.5 bolt...   Mar 26, 2013 - 12:57 AM
- - ILoveMySilly97   That m18x1.5 is for bother the fill and drain nuts...   Mar 26, 2013 - 3:18 AM
|- - Syaoran   QUOTE (ILoveMySilly97 @ Mar 26, 2013 - 4...   Mar 26, 2013 - 6:38 PM
|- - ILoveMySilly97   QUOTE (Syaoran @ Mar 26, 2013 - 4:38...   Mar 27, 2013 - 12:37 PM
- - JoshuaM   Oohh, I have the 3rd gear grinds too and was ignor...   Mar 26, 2013 - 4:51 AM
|- - ILoveMySilly97   QUOTE (JoshuaM @ Mar 26, 2013 - 2:51...   Mar 26, 2013 - 5:07 PM
|- - JoshuaM   QUOTE (ILoveMySilly97 @ Mar 26, 2013 - 5...   Mar 26, 2013 - 5:26 PM
- - rave2n   Soak them in PB blaster for a day. That'll loo...   Mar 27, 2013 - 2:33 PM
- - presure2   and stay away from the 12pt socket if you can, it ...   Mar 31, 2013 - 9:16 AM
|- - ILoveMySilly97   QUOTE (presure2 @ Mar 31, 2013 - 7:1...   Mar 31, 2013 - 4:21 PM
- - ILoveMySilly97   I officially given up. My brother and I was battli...   Apr 5, 2013 - 5:33 PM
- - mkernz22   Use a 1/2" drive and a 24mm socket. Then jack...   Apr 5, 2013 - 10:20 PM
|- - ILoveMySilly97   QUOTE (mkernz22 @ Apr 5, 2013 - 8:20...   Apr 5, 2013 - 10:46 PM
- - bsamps4   I got pissed at mine and gave it a quick blip with...   Apr 8, 2013 - 12:50 PM
- - ILoveMySilly97   Yea. I don't have an impact gun so I'm jus...   Apr 8, 2013 - 2:40 PM
Lo-Fi Version Time is now: August 27th, 2026 - 11:51 AM
