> Cold engine likes to die
post Mar 27, 2013 - 3:37 PM
PaddyTapps
Joined Mar 6, '13
From Tampa
So believe it or not, it's been a little chilly in Florida the past few days. By chilly I mean low to mid 40s. I know its snowing in other parts of the world but for FL, it's chilly! I started my car Monday, turned over just fine and then promptly the rpm's fell to 0 and it died. I tried again, same thing. I thought if i drive it some it'll warm up and be fine. It died 3 more times when the clutch was pushed if, so i had to keep my foot on the gas so it wouldn't die used my left foot to brake to get to work. after about 5-10 minutes of that it would run without dying. I'm thinking that the battery's ok, else it wouldn't have turned over at all correct? Anybody have an idea why a cold engine would die like that? I'm stumped.
This post has been edited by PaddyTapps: Mar 27, 2013 - 3:38 PM
Replies (1 - 19)
post Mar 27, 2013 - 4:24 PM
DST94
Joined May 11, '09
From California
Does it only die when you push the clutch in, or will it just not run at all? And when it does is it abrupt or does it slow down until it dies? Have you done anything to the engine recently?
post Mar 27, 2013 - 4:44 PM
PaddyTapps
Joined Mar 6, '13
From Tampa
As soon as I turn it on it dies so yeah only with the clutch in and not on the gas. Haven't done a thing to the engine.
post Mar 27, 2013 - 6:54 PM
PaddyTapps
Joined Mar 6, '13
From Tampa
Just drove to pick up dinner and on the way back it started to shudder really badly, not only while idling at a stop light but while driving too. Accelerating and even maintaining 30-35 mph i could feel it, almost seemed like it was going to shut down, but never did. I'm thinking it's going to have to go to the dealership this weekend kindasad.gif and that = lotsa $ cuz heck if i know what's goin on
post Mar 27, 2013 - 7:13 PM
Syaoran
Joined Jan 4, '12
From US
It could be a number of things. Plugs, cap, rotor, wires, fuel pump, stuck open injector(s), compression loss... If you haven't replaced any maintenance item (spark plugs, distributor cap & rotor, spark plug wires, fuel filter) I'd start there, since it's a good idea to do it anywho.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Mar 27, 2013 - 10:58 PM
DST94
Joined May 11, '09
From California
QUOTE (Syaoran @ Mar 27, 2013 - 5:13 PM) *
post Mar 28, 2013 - 9:14 AM
PaddyTapps
Joined Mar 6, '13
From Tampa
Thanks guys. I'm tempted to say that it's misfiring, which really is no surprise to me because the car has been neglected for who knows how long. I'm going to replace spark plugs & wires and sea foam the gas tank, oil, and vacuum tube to the intake manifold this weekend and an oil and filter change. Even though she leaks oil, I have no idea when the last one was done so definitely going to get that done. If that clears the issue up, great! if not then I'll look into the distributor cap & rotor and everything else. If all else fails, then to the service center we go kindasad.gif
post Mar 28, 2013 - 9:55 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
save your money, that seafoam is just crap!
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 28, 2013 - 10:06 AM
PaddyTapps
Joined Mar 6, '13
From Tampa
QUOTE (Smaay @ Mar 28, 2013 - 9:55 AM) *
If it helps, I saved $3 on it when i bought it a few weeks ago lol, but I've used it before and had no issues, what makes you say its crap?
post Mar 28, 2013 - 11:18 AM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (PaddyTapps @ Mar 28, 2013 - 11:06 AM) *
On an old vehicle with alot of residue in the intake manifold, which I am assuming you intend to boost it in.
All it does is loosen it up into a gummy form a crud that clogs shiz further.
In the oil right before a change, I mean literally right before not 500 miles later, may help. Along with it potentially cleaning some items in the gas section..but other means are worthless IMO. Clogged the hell out of my TB on my ST when I did it, had to remove and clean it all out.
post Mar 28, 2013 - 12:00 PM
PaddyTapps
Joined Mar 6, '13
From Tampa
hm, never knew that. I used to have a tiburon i used it on and an explorer and never really noticed anything bad. I'll take your guys' word for it though, as I've never had to remove a TB or intake manifold. thanks for the heads up!
post Mar 28, 2013 - 1:00 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
sounds like idle speed valve to me
God made man....
Everything else...
Made in China
post Mar 28, 2013 - 3:34 PM
PaddyTapps
Joined Mar 6, '13
From Tampa
Pulled the spark plugs this is what i found:
in order as if looking at the engine bay straight on
looking down into where that spark plug came from, and notice some stuff around the injector? dunno how that got there.
another view.. looks nasty!
nice n shiny wet spark plug, smells like gas
Is this just a case of bad plugs or is there something else causing that one plug to be soaked in gas?
post Mar 28, 2013 - 5:20 PM
Syaoran
Joined Jan 4, '12
From US
Looks like coked oil to me. Might want to check for leaks into the plugs/oil consumption.
post Mar 28, 2013 - 7:00 PM
PaddyTapps
Joined Mar 6, '13
From Tampa
Oil is definitely leaking from the oil pan gasket, need to get that fixed and check after to see how much oil consumption is goin on. I changed the plugs and wires this afternoon, no more dying but it idles extremely low. It drops down to about 200 rpm on start up and comes back up to about 500. I know the idler pulley needs replacing, but I don't think that the pulley being bad would make my rpms so low.
post Mar 28, 2013 - 7:50 PM
Syaoran
Joined Jan 4, '12
From US
The idler pulley doesn't control your idle. It just helps the tensioner pulley give tension to the belt.
Check the rest of the ignition components, you might need to replace spark plug wires, distributor cap and rotor.
post Mar 28, 2013 - 8:00 PM
PaddyTapps
Joined Mar 6, '13
From Tampa
Yeah I didn't think the pulley had anything to do with it. How can I tell if the the cap and rotor are bad?
post Mar 28, 2013 - 11:06 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (PaddyTapps @ Mar 28, 2013 - 9:00 PM) *
It's hard, but usually they just lose conductivity and cause a weak spark or no spark at all. You can check them and see if they look worn out (dark, luster-less metal for example)
You could also take them to a local autoparts and ask for both and compare. I don't think there's any real "test" for them, they're just one of those maintenance items you replace every couple of months, like the gasoline filter.
post Mar 30, 2013 - 11:40 PM
celica74
Joined Feb 8, '10
From North Carolina
Looks to me like you either have bad rings on #2 or a head gasket leak on #2. My 7a looked like that on #3. Also IAC might need to be cleaned for your idle issue.
post Mar 31, 2013 - 9:45 PM
PaddyTapps
Joined Mar 6, '13
From Tampa
QUOTE (celica74 @ Mar 30, 2013 - 11:40 PM) *
My money is on the rings. When i can afford it they are going to get replaced. Also, I found the thread concerning the 5S-FE IAC cleaning process but my attempt to find one for the 7A-FE hasn't produced anything. Are they in the same place and is it the same process? Thanks for the replies and info everyone!
Lo-Fi Version Time is now: August 29th, 2026 - 1:53 PM
