> turbo problems with serverx13's old celice., new owner problems
post Apr 2, 2013 - 12:22 PM
brommy02
Joined Apr 2, '13
From bluffton I.N.
Ok my car which is severx13's old car I'm the new owner and he told me a lot of you guys can help me. when my car gets to 4 grand rpm my wastegate opens and not too long after it opens it falls on its face and blows black smoke out my wastage at 4500. it will not get any higher than 4500 rpm while driving in any gear. but in neutral it will goto 7000.please if you can help.
This post has been edited by brommy02: Apr 3, 2013 - 1:28 PM
post Apr 2, 2013 - 3:50 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
i need history on the car, build specs, engine management.
and your wastegate opens at a boost level, not a specific RPM. and 4000 is really bad for full boost. what turbo?
This post has been edited by Smaay: Apr 2, 2013 - 3:51 PM
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Apr 2, 2013 - 9:46 PM
brommy02
Joined Apr 2, '13
From bluffton I.N.
i have a t3/t4 50 ml. I'm new to turbos so i don't know a whole lot about them. i have an apexi monitor that might be messed up. i was told I'm getting to much fuel but i don't know how to tune it. it has stuck internals. it's pushing 11 pounds of boost by 4500 rpm and won't get any higher then 4500 because it's just blows black smoke out my wastegate and falls on its face even if i fether it at 4500 it just won't let me get any higher.
post Apr 3, 2013 - 3:20 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Most likely a stuck boost controller or soleniod controlling the boost if its not manually adjusted.
post Apr 3, 2013 - 3:51 AM
brommy02
Joined Apr 2, '13
From bluffton I.N.
i don't have a boost controller on it right now but just bought one you think that will fix my.problem?
post Apr 3, 2013 - 8:56 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
you are pushing 11psi on what engine? you need tuning not a boost controller.
post Apr 3, 2013 - 8:57 AM
DEATH
Joined Dec 19, '07
From tx
Could also be fuel cut perhaps? IDK what ECU he's running so IDK what his stock fuel cut would be, whether he's equipped with a FCD or active MAP clamp etc.
Just a thought.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Apr 3, 2013 - 9:32 AM
From my recollection this is a 5sfte?
you should have a boost controller unless wastegate is just 11psi.
Black smoke is usually fuel or oil. Could be blown turbo seals.
If you don't know much about cars / turbos I would advise taking it to a shop that knows what to do and can help you learn!
post Apr 3, 2013 - 1:18 PM
brommy02
Joined Apr 2, '13
From bluffton I.N.
ok if you goto severx13's profile on YouTube there's a video of my car on the dino when it was running perfect. so it ran perfect at one time. but now there's something wrong. yes it is the 5sfte engine it has a tail wastegate that has a vacuum input on top of it with nothing attached to it. i read that is not that important but again I'm not sure. I'll try to get a video of what its doing today
post Apr 3, 2013 - 1:23 PM
brommy02
Joined Apr 2, '13
From bluffton I.N.
here's the dino run of my car
This post has been edited by brommy02: Apr 3, 2013 - 1:27 PM
post Apr 3, 2013 - 1:37 PM
Don't buy a boost controller. It will not fix anything.
5sfTe's are known to run very rich in the upper rpms. This is mostly due to the fact that your car has larger injectors (because of the turbo), but is still running on the stock ecu. To fix this you will need:
1. A wideband a/f ratio gauge.
2. some type of computer to help tune the fuel curve (your car probably has an apexi safc).
What you want to do is remove fuel from the HIGH corrections map in the safc, so that the wideband reads something in the mid 11 afr range (wide open throttle, at 4-6k rpm). If you don't know how to do this, or don't have a wideband, you will need to visit a dyno and have them figure it out for you. Either that or look around the internet and learn how to do it on your own.
This post has been edited by lagos: Apr 3, 2013 - 1:38 PM
post Apr 3, 2013 - 1:48 PM
brommy02
Joined Apr 2, '13
From bluffton I.N.
Ok I'll give it a try thank you
post Apr 3, 2013 - 5:59 PM
brommy02
Joined Apr 2, '13
From bluffton I.N.
i found a controller and turned it up a little. I'm pushing 13 pounds of boost now but it's still doing it
post Apr 3, 2013 - 7:46 PM
brommy02
Joined Apr 2, '13
From bluffton I.N.
Alright so i turned the high throttle fuel down a little and it helped a lot. it's actually pulling while the wastegate is open. i just need to find someone that can tune it in my area
post Apr 4, 2013 - 10:38 AM
DEATH
Joined Dec 19, '07
From tx
I'm curious as to how you know for certain that your wastegate is open.
EXT: WRC/TRD/404
post Apr 4, 2013 - 3:25 PM
brommy02
Joined Apr 2, '13
From bluffton I.N.
umm probably the ear piercing sound it makes along with my.black exhaust blowing out. and no not my.blow off
Lo-Fi Version Time is now: August 27th, 2026 - 4:28 PM
