> how to instal TRD rear wing, I NEED thoto
post Apr 5, 2013 - 12:13 PM
Lexa666
Joined Mar 15, '10
From Russia
Recently put TRD spoiler
disadvantages:
1-mount.
studs instead of bolts.
2 M8 threaded studs and the holes in the lid 5-6.
3-one opening coincided, the second not. I had to make one more hole.
4 on the back of the lid have to cut a piece of metal to tighten two screws.
5-side panel to fit snugly inside. If the gap.
I need a picture, who is established
1 -
2 -
3 -
4 photos as done
5 is firmly prilegaet.Foto
Done in a hurry, because cover should be changed.
When looking to buy a new one. I want to do this carefully, because changing that restayl (a lot of extra holes), but not heated.
post Apr 5, 2013 - 12:30 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
lolwut?
My Celica!
post Apr 5, 2013 - 1:22 PM
richee3
Joined Jun 29, '08
From Denver
I think he's trying to install the TRD wing and is having difficulty. He's asking for pictures and a how-to. I think he specifically needs pictures of #4 and #5.
Edit: I see the issue. You had a Euro two post wing, which mounts slightly differently from the TRD wing. Only the rear holes line up, so you had to drill the front holes. As for the rest of the issues, does the base of the TRD wing not sit flat against your trunk lid? It might be that you have a TRD wing for a coupe or Curren instead of a liftback wing.
This post has been edited by richee3: Apr 5, 2013 - 1:28 PM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Apr 5, 2013 - 6:04 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
^Did they ever make a TRD wing for liftbacks? I think it was c-one that made one for the liftback that looks similar to the TRD spoiler. Not sure.
post Apr 5, 2013 - 8:05 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (ILoveMySilly97 @ Apr 5, 2013 - 6:04 PM) *
They surely did, and it was sexy. As a matter of fact, two of our fearless moderators (presure2 and Rusty) have the TRD liftback wing.
I want one but the wifey (and legal owner of my Celica) says no.
1998 Celica GT-
BEAMS Swapped.
post Apr 5, 2013 - 8:14 PM
Rusty
Joined Nov 5, '07
From New Zealand
thanks richee3
http://www.6gc.net/forums/index.php?showtopic=49898
has a bit of info that might be useful for lining up the new holes
post Apr 6, 2013 - 3:02 AM
Lexa666
Joined Mar 15, '10
From Russia
QUOTE (richee3 @ Apr 5, 2013 - 1:22 PM) *
Yes, that's right
My rear fender 100% ST202, removed from the 6th gen, for liftback(non curren or supra)
post Apr 6, 2013 - 3:17 AM
Lexa666
Joined Mar 15, '10
From Russia
QUOTE (richee3 @ Apr 5, 2013 - 8:05 PM) *
My rear wing (side) is not adjacent to a body together
Arrow said where.
I think that is not correct to make the hole.
2 rear holes are the same, but the pins are thick. I just increased the diameter of the hole.
2 front-holes do not match.
Made 2 new holes.
put the wing
From inside the trunk had to be very hard
TRD rear wing not bolt on
QUOTE (Rusty @ Apr 5, 2013 - 8:14 PM) *
thanks richee3
before i have the SS3 rear wing(holes)
after 1st install
post Apr 6, 2013 - 9:41 AM
ILoveMySilly97
Joined Mar 8, '12
That's nice to know. If I want a tall spoiler I'll go for the trd wing then. Lol. Never was a fan of the huge gt4 riser blocks or the dcw ones. The euro one, I can bare it. Lol.
post Apr 8, 2013 - 1:10 AM
Lexa666
Joined Mar 15, '10
From Russia
until that useful 1 photo,not the rest of the required info
i need more photo install wing
post Feb 5, 2018 - 8:48 AM
trdproven
Joined Aug 2, '05
From Guam
Wanted to ask if I have the two post spoiler is the trd spoiler direct fit or do I need to drill extra? Was the original problem going from 3 post?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 5, 2018 - 11:01 AM
cheela
Joined Feb 2, '07
From Berlin, WI
If you have the 2 post, it should fit, no holes needed.
I think in this post, the problem was they had the euro 2 post spoiler which is shorter in length than the JDM/OEM 2 post so only one hole matched. the 3 post would be the same issue, only one hole matched and have to drill the second. I believe you have a regular 2 post and not the euro 2 post so you should be fine.
post Feb 5, 2018 - 11:04 AM
cheela
Joined Feb 2, '07
From Berlin, WI
here's a pic to show the difference.
post Feb 5, 2018 - 7:28 PM
trdproven
Joined Aug 2, '05
From Guam
got it thanks a million, i figured those were the issues when rusty got his spoiler since his was 3 post and I remembered there was a shorter base 2 post.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 15, 2018 - 12:31 PM
Montagemz
Joined Jan 26, '18
From Norway
This post has been edited by Montagemz: Feb 8, 2019 - 10:30 PM
post Feb 16, 2018 - 2:30 PM
cheela
Joined Feb 2, '07
From Berlin, WI
no, it's the same process as converting from 3-post to 2-post. 2 out of 4 holes will match up. and then you just have to drill 2 more and cover up the other ones. It's not all that hard. there's a few posts about it on here.
post Feb 22, 2018 - 10:46 PM
trdproven
Joined Aug 2, '05
From Guam
the true all universal standard for all the hatch wings, is the longer base 2 post. the shorter 2 post and 3 post will still create work (drill or cover up). the standard 2 post, which is the longer base, alllows for the riser blocks, and trd spoiler, and many aftermarket.
This post has been edited by trdproven: Feb 22, 2018 - 10:47 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: August 24th, 2026 - 7:11 AM
