Apr 12, 2013 - 2:13 PM
Enthusiast Joined Sep 26, '10 From Kentucky Currently Offline Reputation: 0 (0%) |
I just need a little reassurance before i go rip all my belts off. My alternator belt is fine, was replaced about 6 months ago with the alternator. Where do I loosen the power steering belt? and is there an idler pulley on the a/c belt? and if so where? thanks for the help
Apr 13, 2013 - 6:39 AM
Nothing?... so does nobody change their belts here?
Apr 13, 2013 - 6:54 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
is this on a 5sfe or 7afe?
-------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Apr 13, 2013 - 11:25 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
Remove passenger side wheel, remove plastics.
Find the bottom bolt on the pump, loosen it, which will loosen tension. Enjoy working in a hellish spot if its a 5s. Enjoy slightly more freedom with the 7A. 2 bolts. 1 Pry bar. Remove the AC belt to do the PS belt. |
Apr 13, 2013 - 12:34 PM
Enthusiast ![]() ![]() ![]() Joined Jan 26, '09 From Los Angeles Currently Offline Reputation: 1 (100%) |
Remove passenger side wheel, remove plastics. Find the bottom bolt on the pump, loosen it, which will loosen tension. Enjoy working in a hellish spot if its a 5s. Enjoy slightly more freedom with the 7A. 2 bolts. 1 Pry bar. Remove the AC belt to do the PS belt. Don't even think about trying to change your PS belt from the hood with a 5S It is an absolutely awful spot..but the best way is through the passenger wheel well, for sure. -------------------- |
Apr 13, 2013 - 9:57 PM
its an old 7afe. but removing the wheel does sound like the best idea. this will be tight since this side of my car is a little damaged from a deer hit recently. does the a/c belt have idler pulley?
Apr 14, 2013 - 11:19 AM
its an old 7afe. but removing the wheel does sound like the best idea. this will be tight since this side of my car is a little damaged from a deer hit recently. does the a/c belt have idler pulley? You tension the AC pulley or that assembly by a bolt underneath the alt. Its either a 10mm or 12mm can't recall. Slightly hidden. This post has been edited by rave2n: Apr 14, 2013 - 11:20 AM |
Apr 18, 2013 - 3:01 PM
well im finally about to go for it... hope i dont have any problems because its my only mode of transport.
| Lo-Fi Version | Time is now: September 12th, 2026 - 4:46 AM |
