Apr 28, 2013 - 6:16 AM
Enthusiast ![]() Joined Dec 20, '11 From gta Currently Offline Reputation: 0 (0%) |
Just recently had a new distributor put in. I also had a new engine put into my celica in 2012 (st204). I had the engine rev to 3500 rpm in a parking lot and it got stuck there. It came down a bit when I revved higher in order to try and stop it (with the clutch depressed of course). It kept up between 2000 - 3500 rpm until I parked it and shut it off. Hasn't had that problem since, in the last two weeks. Is this something diagnosable? Is it something I should be worried about?
Apr 28, 2013 - 6:28 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
first check to make sure the foot carpet isnt getting stuck in front of the pedal.
then rev the engine using the throttle cable line o make sure it isnt a sticky throttle cable line -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Apr 28, 2013 - 8:49 PM
Enthusiast ![]() Joined Aug 23, '12 From New jersey Currently Offline Reputation: 0 (0%) |
Apr 29, 2013 - 1:19 PM
sounds like a vacuum leak that fixes itself. like a hose is cracked
Apr 29, 2013 - 1:45 PM
Enthusiast Joined Feb 26, '13 From North Carolina Currently Offline Reputation: 5 (100%) |
Just recently had a new distributor put in. I also had a new engine put into my celica in 2012 (st204). I had the engine rev to 3500 rpm in a parking lot and it got stuck there. It came down a bit when I revved higher in order to try and stop it (with the clutch depressed of course). It kept up between 2000 - 3500 rpm until I parked it and shut it off. Hasn't had that problem since, in the last two weeks. Is this something diagnosable? Is it something I should be worried about? I'm pretty sure the throttle cable is sticking or the throttle itself is somehow getting stuck open. Nothing io serious. -------------------- "You may pass me on the straights, but I'll eat you up in the corners."
Apr 29, 2013 - 2:51 PM
a stuck throttle cable is very serious! you need to look under the hood to confirm that the throttle plate is closing while its revving like that
| Lo-Fi Version | Time is now: July 31st, 2026 - 9:35 AM |
