May 5, 2013 - 12:11 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 12, '13 Currently Offline Reputation: 53 (100%) |
Hello. I am looking into making my own strut bars. I have most of the needed instrument and the desire is there. I just don't feel like paying for it when I can do it on my own.
I want to make one for the back and a 3 point strut bar for the front. What are your recommendations when it comes to the fabrication? What material should I use? What should be my first steps? Should the front and back respectively be lifted before I start doing any fab work? My plan is to make the circle mounts that are above the suspension, attached with the original 3 bolts. Then the one that is on the firewall. Cut my metal to length and tack weld it to the mounts. Remove from the car and reinforce the welds. Clean up welds and paint. Same for the back. Similar to these: ![]() ![]() ![]() Thanks. |
The_enD Making my own front and back strut bars? May 5, 2013 - 12:11 PM
BonzaiCelica Our cars would benefit from a rear 3 point strut b... May 5, 2013 - 11:50 PM
Box I would say make it out of steel. Cheaper and gen... May 6, 2013 - 12:16 AM
The_enD Thanks
I'll probably lower her+sway bars+strut... May 6, 2013 - 3:08 AM
UVZ164 Have a read through this:
http://www.6gc.net/foru... May 6, 2013 - 3:53 AM
playr158 DEFGEPH (an OG here who is long since past this ti... May 6, 2013 - 5:02 AM
The_enD Thanks, I search for " +strut +fabricate... May 6, 2013 - 5:03 AM
BonzaiCelica yea steel for the rear would be just fine. it woul... May 7, 2013 - 12:33 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 10:09 PM |
