May 7, 2013 - 9:26 PM
Enthusiast ![]() ![]() Joined Nov 29, '07 From Colorado Currently Offline Reputation: 4 (100%) |
So here's my Celica as she stands now:
![]() And when I got her, nearly 6 years ago at 139,000 miles: ![]() She's a 1994 GT. Fully stock when I bought it(wheels aside). Perfectly clean. Never been in an accident. Now it's got whited out JDM Tails, ST Suspensions sway bars, new Konig wheels and Megan Racing coilovers. A few weeks ago I started getting some possible signs of a broken head gasket. So, I decided to dive in and do something that I've been wanting to do for a while. So, today I got: .Gaskets are on their way. I've already got a new clutch and some motor mounts. New cluster is on it's way too. Just setting to work on electrical until then! -------------------- 2019 M2, 2005 S2000, 1997 4Runne
aspen My Celica, with BEAMS May 7, 2013 - 9:26 PM
JoshuaM BEAMS AWESOMENESS!!!!
Good luck ... May 8, 2013 - 2:35 AM
richee3 Will you be extending the harness or going through... May 8, 2013 - 5:42 AM
aspen I'm planning on extending the harness the 40 s... May 8, 2013 - 8:50 AM
richee3 I extended mine 24" which was still a little ... May 8, 2013 - 9:15 AM
aspen So you'd do closer to 20"? And it's j... May 8, 2013 - 9:33 AM
Malek I put a hole in my firewall haha May 8, 2013 - 12:44 PM
richee3 20-24" is good. Like I said, mine was a littl... May 8, 2013 - 2:01 PM
aspen Good deal. I'll start on it this weekend after... May 8, 2013 - 6:04 PM
aspen First take at 3D Printing extra BEAMS logos: May 8, 2013 - 7:38 PM
aspen Started work on the wire harness:
Got my gauge c... May 14, 2013 - 5:51 PM
S8S8 Welcome to the Beams family. May 15, 2013 - 4:47 AM
aspen Worked yesterday to free the new engine from the f... May 19, 2013 - 9:11 AM
Syaoran I like that white faced cluster. What is it from? May 24, 2013 - 11:59 AM
aspen Those are the gauges from an SS-III.
Also, got th... May 29, 2013 - 6:22 PM
Box Good job so far, and good luck on your swap. Fina... May 29, 2013 - 7:06 PM
ricochet1490 I have super strut everything in the front. 5s reg... May 29, 2013 - 7:47 PM
aspen Been working on the head and block. Unfortunately ... Jun 13, 2013 - 10:17 PM
aspen The BEAMS is in. And Runs. (Started on the first t... Jun 23, 2013 - 7:46 PM
Box QUOTE (aspen @ Jun 23, 2013 - 7:46 P... Jun 23, 2013 - 9:26 PM
richee3 No problem, glad to help out and glad to hear your... Jun 23, 2013 - 8:15 PM
aspen And got a 2.5" exhaust welded up. Still a few... Jun 27, 2013 - 10:15 AM
ricochet1490 Mine has high idle as well. Average between 1200 a... Jun 27, 2013 - 1:30 PM
BonzaiCelica QUOTE (ricochet1490 @ Jun 27, 2013 - 1... Jun 27, 2013 - 1:33 PM
ricochet1490 QUOTE (BonzaiCelica @ Jun 27, 2013 - 2... Jun 27, 2013 - 2:18 PM
aspen I cleaned my ICSV. I hope I don't have to repl... Jun 27, 2013 - 3:52 PM
aspen Well, new airbox, sort of bled the coolant (I had ... Jun 27, 2013 - 8:51 PM
richee3 A BEAMS is supposed to idle at 750, and the ISCV s... Jun 27, 2013 - 9:28 PM
aspen I realized going through the cleaning again that I... Jun 27, 2013 - 9:32 PM
richee3 Now you're onto something. The motors get hor... Jun 27, 2013 - 9:47 PM
Box *PRO TIP*
Use an angled screwdriver on the brass s... Jun 27, 2013 - 9:52 PM
aspen Heh, I already cut those off (or turned them into ... Jun 27, 2013 - 9:56 PM
Batman722 QUOTE (aspen @ Jun 27, 2013 - 10:56 ... Jun 28, 2013 - 8:20 AM
Box Way to be a typical male.
You can hook the ISCV ... Jun 27, 2013 - 10:04 PM
aspen I didn't have my impact driver handy! Jun 27, 2013 - 10:06 PM
aspen I'll keep that in mind. Cleaned it again thoug... Jun 28, 2013 - 9:49 AM
richee3 At least the idle is improved! I doubt if you ... Jun 29, 2013 - 7:17 PM
aspen Running wise, it seems to have improved. I drove ~... Jun 30, 2013 - 3:18 PM
onnaj Maybe air in the system? Jack the car up in the fr... Jul 1, 2013 - 5:44 AM![]() ![]() |
| Lo-Fi Version | Time is now: September 14th, 2026 - 6:07 PM |
