May 20, 2013 - 12:10 PM
Enthusiast ![]() Joined Aug 2, '11 From southampton Currently Offline Reputation: 0 (0%) |
Hi guys, don't post on here really as post on a UK celica forum.... but thought I would share what I have done to my SSI.
Following the various 5sfte posts and guidance, I have now turbo'd my 3sfe engine, some pics of the engine bay (its had a little more done since this one - including changing boost gauge t-off point to the map sensor line) and other bits at end of post. Have installed; 3sge injectors ct26 turbo emanage blue (getting tuned in a couple of weeks) ST185 manifold ST185 map sensor 2.25" intercooler pipes and intercooler Apexi BOV ST185 pan boost and oil gauges 2.5" custom ss exhaust Been a fun and frustrating build, the turbo would not clear the coolant hard lines on the rev 3 3sfe, so I had to source a spacer for between the manifold and turbo. Changing the oil pan is fun too! Didn't need to relocate oil filter, so that was a bit easier. Coolant lines off the throttle body so again pretty easy. Intercooler piping was interesting, right side through air pox route, left side was a bit of a squueze! But did not need ot remove a/c or anything else. Not driven it on boost yet, but has been driven for several hours off boost, and doesn't miss a beat. Injector size has gone from 215cc (rev 3 3sfe stock I believe) to 295 (3sge stock), running on stock fuel pump, so some scope to improve there. First map though is just a safe one to ensure no det, etc. Plans next will be; wideband sensor and gauge (hooked into emanate) prob bigger injectors and fuel pump sort out second output for boost gauge from throttle bottle to leave map sensor feed unmolested Wilwood 4 pot brakes looking forward to running boost! ![]()
This post has been edited by digs: May 20, 2013 - 1:56 PM |
digs 3SFTE project May 20, 2013 - 12:10 PM
Smaay i ran my 5S-FTE setup without the water lines. you... May 20, 2013 - 12:24 PM
digs QUOTE (Smaay @ May 20, 2013 - 1:24 P... May 20, 2013 - 12:29 PM
digs How safe then is it to drive on boost as set up? N... May 20, 2013 - 12:39 PM
Smaay i would also suggest you change that water hose ri... May 20, 2013 - 12:50 PM
digs QUOTE (Smaay @ May 20, 2013 - 1:50 P... May 20, 2013 - 12:54 PM
Syaoran My recommendation would be to get at least 440cc i... May 20, 2013 - 1:31 PM
digs I do think I will need bigger injectors, so useful... May 20, 2013 - 1:51 PM
Syaoran QUOTE (digs @ May 20, 2013 - 2:51 PM... May 20, 2013 - 4:28 PM
Smaay all 2ZZ injectors are High Impedance. but they are... May 20, 2013 - 5:44 PM
Syaoran QUOTE (Smaay @ May 20, 2013 - 6:44 P... May 20, 2013 - 7:52 PM
Smaay QUOTE (Syaoran @ May 20, 2013 - 5:52... May 21, 2013 - 8:23 AM
95CelicaST QUOTE (Smaay @ May 21, 2013 - 6:23 A... May 21, 2013 - 9:40 AM
Syaoran QUOTE (Smaay @ May 21, 2013 - 9:23 A... May 21, 2013 - 11:37 AM
digs QUOTE (Smaay @ May 20, 2013 - 6:44 P... May 21, 2013 - 10:44 AM
Syaoran Exige S:
The RX-7 high impedance 550cc injectors... May 20, 2013 - 7:59 PM
digs Thanks guys , really appreciate your input May 21, 2013 - 1:06 AM
digs Just an update, i have changed my PCV system with ... Jun 20, 2013 - 7:43 AM
Syaoran QUOTE (digs @ Jun 20, 2013 - 8:43 AM... Jun 20, 2013 - 1:50 PM
Smaay there is a check valve in the brake booster. dont ... Jun 20, 2013 - 9:03 AM
digs QUOTE (Smaay @ Jun 20, 2013 - 10:03 ... Jun 20, 2013 - 10:52 AM
digs Good to hear, makes that a bit easier
Thanks, lo... Jun 20, 2013 - 3:49 PM
digs 460cc injectors have arrived - had a thought thoug... Jul 9, 2013 - 4:23 AM
Syaoran QUOTE (digs @ Jul 9, 2013 - 5:23 AM)... Jul 9, 2013 - 1:13 PM
digs QUOTE (Syaoran @ Jul 9, 2013 - 2:13 ... Jul 9, 2013 - 1:23 PM
Syaoran I recommend not using it and waiting to get someth... Jul 10, 2013 - 8:06 PM
digs Thought I would swing by and update, engine still ... Dec 3, 2013 - 8:30 AM
H8TRAIN Very interesting, digs. I'm glad you posted th... Dec 5, 2013 - 10:06 PM
digs QUOTE (H8TRAIN @ Dec 5, 2013 - 10:06... Dec 9, 2013 - 3:57 PM
Syaoran 5S-FE was built for torque, not horsepower. The 3S... Dec 9, 2013 - 7:47 PM
H8TRAIN QUOTE (Syaoran @ Dec 9, 2013 - 7:47 ... Dec 10, 2013 - 12:01 AM
Syaoran QUOTE (H8TRAIN @ Dec 10, 2013 - 1:01... Dec 10, 2013 - 2:18 PM
delusionz ^--- Yup. Dec 10, 2013 - 2:12 PM
delusionz i dont think a 3sg head on a 3sf block would make ... Dec 12, 2013 - 1:23 AM
digs QUOTE (Syaoran @ Dec 9, 2013 - 7:47 ... Dec 12, 2013 - 6:49 AM
Syaoran It all depends on the turbo you're using.
3S-... Dec 12, 2013 - 11:03 PM
H8TRAIN QUOTE (Syaoran @ Dec 13, 2013 - 12:0... Dec 14, 2013 - 12:53 PM
digs Thanks for the info...
Tuning: Once the full thr... Dec 16, 2013 - 6:32 AM
digs an update...just grabbed a ST205 shell with engine... Feb 21, 2014 - 3:55 PM![]() ![]() |
| Lo-Fi Version | Time is now: July 30th, 2026 - 7:04 PM |
