> 194 bulb for projector accents, Need help to find a good bulb
post May 21, 2013 - 11:27 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
I currently have some chrome amber bulb in my accents and it doesn't light up real bright at all. It's barely noticeable. So now I'm thinking of switching over to LED. Anyone running amber accent lights? I want to see some pics and give me some info on the brand and where I can buy it.
Replies (1 - 16)
post May 22, 2013 - 10:33 AM
199celica
Joined Jul 29, '11
From chino, Ca
If you would like a top quality 194 bulb I recommend the cree led by ddmtuning.com they are a bit pricey but well worth it.
post May 22, 2013 - 12:20 PM
ILoveMySilly97
Joined Mar 8, '12
Well have to check it out when I get on my computer.
post May 22, 2013 - 8:31 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
i got some off ebay, the 194 smd leds for super cheap, like 10 for 8 bucks or something, i got them long time ago.
here are some pics. not sure if ur looking for these or something else. hope this helps.:
http://www.6gc.net/forums/index.php?showtopic=87947&hl=
post May 22, 2013 - 10:35 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Malhar95 @ May 22, 2013 - 6:31 PM) *
How long did they last? Like a year?
post May 23, 2013 - 4:28 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (ILoveMySilly97 @ May 22, 2013 - 10:35 PM) *
still running. from the set i bought maybe one or two blew out but they're still running good. i have them on my new projector set.
for the wiring for the bulb i went to the junk yard and got some 3rd brake light harness that fitted the projectors and then wired it to the side fender light.
just get the 5-smd lights, not the single one
post May 23, 2013 - 7:43 PM
richee3
Joined Jun 29, '08
From Denver
I'm rocking Diode Dynamics LED's in both the Celica and the 350Z. Price is decent, and they are by far the best LED's I've owned.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post May 23, 2013 - 8:52 PM
ILoveMySilly97
Joined Mar 8, '12
I bought some Samsung led off of eBay for $12 shipped for two. Pricey but hopefully its worth it.
post May 24, 2013 - 1:57 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
Let me know how they're compared to others...I might get an expensive set too
post Jun 12, 2013 - 3:53 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Malhar95 @ May 24, 2013 - 11:57 AM) *
Finally installed them and damn. They're bright! You can actually still see them with my Lo beams on. smile.gif
post Jun 12, 2013 - 7:11 AM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
Rentaspace and myself are still trying to decide how we want to wire ours up tongue.gif (We don't have side markers in AUS - just the JDM side indicators wink.gif ).
Are they easy enough to access the side bulbs once the headlights are installed? Just trying to work out if I organize all of the sidelight stuff before or after I install the rest tongue.gif
post Jun 12, 2013 - 10:54 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (JoshuaM @ Jun 12, 2013 - 5:11 AM) *
Nope. The only way to get to the accent lights is by taking off the lo beam. So you might as well do have everything and do everything at once. Lol. You can wire it up with your turn signals. I wished I would've done that instead. So I can delete the turn signal in the future when I get my car painted.
post Jun 12, 2013 - 1:40 PM
travisxcore
Joined Mar 24, '11
From 704
If you wanna do it easy just splice them into the front indicators. Solid green is your park lights, and green-striped is your turn signal.
post Jun 12, 2013 - 5:27 PM
JoshuaM
Joined Mar 6, '12
Thanks Silly.... Another thing to do before I can put them on though... tongue.gif
And I didn't realise that the USDM models don't have accent / parker bulbs built into your low beam headlights, so all of the threads I had been reading were kinda irrelevant tongue.gif All I need to do is splice into the wiring or make up a harness adapter for the parker bulb that is already there tongue.gif
And I don't have any plans for shaving it / removing anything at the moments, so I would prefer to keep them as parkers smile.gif
post Jun 13, 2013 - 8:17 AM
rentaspace
Joined Sep 23, '12
From Australia
I have bought MANY LEDs for the car over the past year, and I have to say that a good 50 - 60 % have started flickering and breaking kindasad.gif
Anyway, my real question is, how hot does it get inside the accent light when the Low beam is turned on? On the ADM lights, the Park lights are located within the same unit as the Low Beam lgiht, and as a result there is A LOT of heat, enough to actually cause my LEDs to catch fire (I switched over the blue tinted bulbs after this).
Will the heat in the accent light be comparable? If not, I will consider some good quality LEDs for them since I don't want to be removing my bumper unnecessarily to change blown LEDs...
post Jun 13, 2013 - 12:41 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (rentaspace @ Jun 13, 2013 - 8:17 AM) *
Where are you putting these LED's at? I kept having the same problem in my gauges. Kind of a stupid thread, but has some good information.
http://www.6gc.net/forums/index.php?showto...mp;#entry827309
1998 Celica GT-
BEAMS Swapped.
post Jun 14, 2013 - 7:16 AM
rentaspace
Joined Sep 23, '12
From Australia
QUOTE (richee3 @ Jun 13, 2013 - 12:41 PM) *
Dashboard, Accent (Park Lights), Glove box, Cig lighter, Ash Tray, Boot Storage thingy under the head unit etc...
Lo-Fi Version Time is now: August 29th, 2026 - 12:50 PM
