May 28, 2013 - 6:27 PM
Enthusiast ![]() Joined Sep 25, '11 From GreatSmokyMtns NC Currently Offline Reputation: 3 (100%) |
got my exhaust installed today. I have a check engine light on. My 2nd 02 sensor is not installed yet. The one on the car has a bracket with two holes and the cat I have has a threaded hole for the sensor. Do they make one for the car that has threads? I found one at the parts store but it only has one wire. 95 st. 7afe
May 28, 2013 - 6:30 PM
Being you have a 1995, try shoving a paper clip into the harness where the second O2 sensor plugs in. It works for many other things on OBDI cars, kind of curious if it'll work here as well.
May 28, 2013 - 8:25 PM
They make adapters.
http://www.ebay.com/itm/O2-SENSOR-BUNG-fla...bf0&vxp=mtr Is that what you're looking for? Don't shove any paperclips in any sensor connectors. :rofl: This post has been edited by Bitter: May 28, 2013 - 8:26 PM -------------------- |
May 28, 2013 - 8:33 PM
Enthusiast ![]() ![]() Joined Mar 4, '10 From Bronx NY Currently Offline Reputation: 3 (100%) |
The braket comes off ... If im understanding you right your old sensor on the car has the the bracket on it .... and your new ehuast dioes not ... if thats the case then just unscrew the bracket off and use the thread to screw directly into the Cat. If the other way then Bitter is correct you can buy the bracket even at a Auto store...
-------------------- Always fast and going for the look......
May 28, 2013 - 8:48 PM
I did not know it would unscrew. I have to extend it about two foot so I'll take it off this weekend. I could have never done all this work without the help of all you guys on this site. Thank you!
May 28, 2013 - 8:54 PM
Don't shove any paperclips in any sensor connectors. :rofl: Why not? It doesn't hurt anything, and it got rid of the check engine light due to my EGR showing its ass. -------------------- 2001 Miata LS 5-speed
May 28, 2013 - 9:24 PM
OH, I got it backwards. I don't think they make an adapter to go from flange style to threaded. You'll need to get a threaded sensor (you can splice in a universal) and then use a spacer to set it back from the exhaust stream so it doesn't throw a code for the missing cat. I remember from your build thread that you have an ebay header which deletes the warmup catalyst. You must have a California emissions Celica? Does the stock exhaust manifold have a catalytic converter on it?
http://www.ebay.com/itm/HHO-Small-O2-Space...2e0&vxp=mtr Something like that, you may need to play with the length of the spacer to get it to not throw a code for the missing cat. Some spark plug non foulers are the right thread, you just drill the end out larger, smaller or larger hole can act like a longer or shorter spacer. -------------------- |
May 28, 2013 - 10:38 PM
okay question ???? does the O2 sensor you have , does it it have thread after the flange at the tip ??as if you could thread it now with the flange on??? if so then unscrew the flange....
May 28, 2013 - 11:09 PM
![]() ![]() but you know what lets see what other guys say cause its possible that only applies to universal style but lets see -------------------- Always fast and going for the look......
May 28, 2013 - 11:22 PM
I'm still backwards.
I think he's saying he has a hole with threads on the pipe The car has a sensor with a flange. He would need a flange that threads into the hole in the pipe, I don't think that exists. -------------------- |
May 29, 2013 - 1:11 AM
I'm still backwards. I think he's saying he has a hole with threads on the pipe The car has a sensor with a flange. He would need a flange that threads into the hole in the pipe, I don't think that exists. correct ..... but what i'm NOT saying is buy a flange adapter to go over the hole to adapt to the flange on the o2 sensor ---- What I am saying is I believe the flange on his existing o2 can screw off. then he would just have to screw it into the existing hole... hoping someone can confirm that This post has been edited by timdog1720: May 29, 2013 - 1:14 AM -------------------- Always fast and going for the look......
May 29, 2013 - 1:12 AM
On the OBDI 7A-FE you have an one wire O2 sensor that's in the manifold, then a catalytic converter at the base of that manifold and downstream of that O2 sensor. Then you have some down-pipe and then you have a two wire O2 sensor then a little further there's a small catalytic converter that isn't monitored. If the first one is just a pre-cat why would it be monitored? Even on OBDII cars I've seen pre-cats not be monitored.
May 29, 2013 - 7:12 AM
I don't think the flange comes off, I'm pretty sure it's part of the sensor body.
Not all 7A-FE have 2 cats, just the California emissions spec as far as I know. -------------------- |
May 29, 2013 - 11:37 AM
I don't think the flange comes off, I'm pretty sure it's part of the sensor body. Not all 7A-FE have 2 cats, just the California emissions spec as far as I know. Mine is the OBDI Fed spec and does. I know ones sold over in Europe have a tubular header of sorts with no pre-cat. Who knows, as if the cats are really holding back the 7A anyway. -------------------- 2001 Miata LS 5-speed
May 29, 2013 - 7:28 PM
Odd, I swore I've seen 7A's with and without pre-cat. I guess I'm wrong and thinking of Corolla and not Celica. Carry on...
May 29, 2013 - 8:13 PM
The Corolla I believe didn't have the pre-cat on OBDI years, but for whatever reason the Celica did.
May 29, 2013 - 8:46 PM
I checked today and I could not get it to unscrew looks like it is all one piece. the first one mounts on the header and the second needs to screw into the resonator/cat combo. as long as it has two wires can i just splice one in from another car?
May 29, 2013 - 9:49 PM
if i had to assume I would say yea if its for a toyota but y cant you buy a universal
May 29, 2013 - 10:25 PM
I think you can just splice in a universal thread in sensor as long as the wires are matched up correctly.
May 29, 2013 - 11:00 PM
I'll pick up a universal this weekend and give it a try.
| Lo-Fi Version | Time is now: September 11th, 2026 - 6:08 PM |
