May 29, 2013 - 2:21 PM
Enthusiast ![]() Joined May 16, '10 From california Currently Offline Reputation: 1 (100%) |
May 30, 2013 - 12:28 PM
too bad u wont ship
May 30, 2013 - 1:22 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
-------------------- st205 powered ss3 coupe
May 30, 2013 - 3:05 PM
i can also ship too much of a hustle but i can do it
of course you have to pay for it and paypal fees..... i also have a 3sgte thats rebuilt i can also ship car got parted out has wiring harness for a 93 celica turbo (not awd) give me a call 714 737 8874 first come first serve im located in cerritos ca This post has been edited by 3sgelevin: Oct 23, 2013 - 3:42 PM |
May 30, 2013 - 3:24 PM
oh i see that is not a E153? is it not? looks like a gear driven speed sensor
May 30, 2013 - 7:51 PM
Enthusiast ![]() Joined Feb 23, '09 From 12803 Currently Offline Reputation: 0 (0%) |
May 30, 2013 - 9:41 PM
I think u need toread my post. One sentence one question, not related. Looks more like a s54 most jdm e153 are from mr2turbo hence shifter brackets. These ones are pointing rear. Oh and it looks like a gear driven speedo .... Lol... If its a Caldina e153. Does not appear to. Be one. I'd like to see the 5th gear cover and the oil coolant lines
May 30, 2013 - 9:48 PM
I read it as you were useing the fact that it had a gear driven speedo the reason why it's couldn't be an e-153. I don't think it's a e-153 tranny myself. Could possibly be s54 tranny with an aftermarket diff. If it was a caldina tranny it would have a stamped metal 5th gear cover and a bolt on shifter cable bracket.
May 30, 2013 - 9:57 PM
I read it as you were useing the fact that it had a gear driven speedo the reason why it's couldn't be an e-153. I don't think it's a e-153 tranny myself. Could possibly be s54 tranny with an aftermarket diff. If it was a caldina tranny it would have a stamped metal 5th gear cover and a bolt on shifter cable bracket. Yup. My bad for using tablet to post and uto correct with bad punctuation -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
May 31, 2013 - 11:24 AM
it has 20 splines more pictures
![]() P1040145 by nakahachi, on Flickr ![]() P1040146 by nakahachi, on Flickr ![]() P1040147 by nakahachi, on Flickr wiring harness with fusebox plug and play no ecu got to get your own $350 like what I said this was on a working car with intake manifold injectors fuel rail throttle etc ![]() P1040149 by nakahachi, on Flickr ![]() P1040150 by nakahachi, on Flickr clutch kit spec $375 ![]() P1040222 by nakahachi, on Flickr ![]() P1040221 by nakahachi, on Flickr rebuild head $550 shipped ![]() P1040143 by nakahachi, on Flickr the block I can have it done also but will wait for perspective buyer I would like to sell everything as much as possible all together which is easier This post has been edited by 3sgelevin: Oct 20, 2013 - 8:19 AM |
Jun 11, 2013 - 9:59 AM
will ship
no one building a car |
Jun 11, 2013 - 5:56 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
I think u need toread my post. One sentence one question, not related. Looks more like a s54 most jdm e153 are from mr2turbo hence shifter brackets. These ones are pointing rear. Oh and it looks like a gear driven speedo .... Lol... If its a Caldina e153. Does not appear to. Be one. I'd like to see the 5th gear cover and the oil coolant lines It is definitely an S-series trans (S51 / S54). Not the factory LSD either. There is a small chance that it is an aftermarket LSD. It would be good to know what car it came out of and the history of the trans. It was obviously in an older car (say, pre '94 Celica or pre '92 Camry or something) due to the cable speedo drive.-Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Jun 11, 2013 - 6:32 PM
came off a 93 celica convertible that had a 3sgte conversion on it
customer decided to get a new front clip had a chance to test drove the car before it blew a headgasket no grinds or anything I think u need toread my post. One sentence one question, not related. Looks more like a s54 most jdm e153 are from mr2turbo hence shifter brackets. These ones are pointing rear. Oh and it looks like a gear driven speedo .... Lol... If its a Caldina e153. Does not appear to. Be one. I'd like to see the 5th gear cover and the oil coolant lines It is definitely an S-series trans (S51 / S54). Not the factory LSD either. There is a small chance that it is an aftermarket LSD. It would be good to know what car it came out of and the history of the trans. It was obviously in an older car (say, pre '94 Celica or pre '92 Camry or something) due to the cable speedo drive.-Charlie |
Jun 11, 2013 - 7:08 PM
Enthusiast ![]() ![]() Joined Feb 28, '11 Currently Offline Reputation: 5 (100%) |
That tranny is from a 90s celica
Jun 12, 2013 - 8:45 PM
NEEDS TO SELL
TAKING SO MUCH SPACE |
Jun 14, 2013 - 8:29 PM
friday bump
Oct 20, 2013 - 8:20 AM
sunday bump
Oct 20, 2013 - 2:45 PM
Enthusiast ![]() Joined Feb 6, '11 From TORRANCE Currently Offline Reputation: 0 (0%) |
i can also ship too much of a hustle but i can do it of course you have to pay for it and paypal fees..... i also have a 3sgte thats rebuilt i can also ship car got parted out has wiring harness for a 93 celica turbo (not awd) give me a call 714 574 0555 first come first serve im located in cerritos ca how much r u selling the rebuilt 3sgte for? |
Oct 23, 2013 - 3:44 PM
i sold that one but i can build you another one
im just finishing up on a 2jzgte motor hit me up 714 737 8874 i also have je pistons if you want it installed |
| Lo-Fi Version | Time is now: September 12th, 2026 - 12:53 AM |
