May 30, 2013 - 12:22 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 5, '09 From West Texas, USA Currently Offline Reputation: 20 (100%) |
After longish drives my coolant overflows. Temp gauge sits exactly in the middle but as soon as I park after a drive it overflows. It could be my radiator but I'm not 100% sure. Thermostat was replaced only a few months ago, and my cap was replaced at the same time. Any other ideas as to what it could be?
May 30, 2013 - 12:26 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
Internal leak, exhaust gases goes into the coolant line either through head gasket or cracked cylinder head.
-------------------- God made man....
Everything else... Made in China ![]() |
May 30, 2013 - 12:33 AM
Internal leak, exhaust gases goes into the coolant line either through head gasket or cracked cylinder head. **** I hope its not that. I don't think its the head gasket because my oil isn't milky or anything. This post has been edited by 1994Celica: May 30, 2013 - 12:34 AM -------------------- |
May 30, 2013 - 1:00 AM
Internal leak, exhaust gases goes into the coolant line either through head gasket or cracked cylinder head. **** I hope its not that. I don't think its the head gasket because my oil isn't milky or anything. Same as mine before. No signs of water in oil or oil in the water. My cylinder head had cracks so the exhaust gases escape in the cooling system. -------------------- God made man....
May 30, 2013 - 1:43 AM
Easy way to find out is to do a compression check.
This post has been edited by Box: May 30, 2013 - 1:43 AM -------------------- 2001 Miata LS 5-speed
May 30, 2013 - 2:28 PM
Took it in to my mechanic. Hopefully it wont be a cracked cylinder head, but I wont be surprised if it is.
May 30, 2013 - 2:48 PM
May 30, 2013 - 3:08 PM
is it a 5S or 7A? i have a good rebuilt 7A-FE head that I rebuilt. it has all new valve seal gaskets, i cleaned and lapped all the valves. checked the clearances. its ready to be installed.
May 30, 2013 - 3:17 PM
is it a 5S or 7A? i have a good rebuilt 7A-FE head that I rebuilt. it has all new valve seal gaskets, i cleaned and lapped all the valves. checked the clearances. its ready to be installed. Its a 5s. -------------------- |
May 30, 2013 - 4:19 PM
I just had a thought. When the thermostat was replaced, was the cooling system burped? I would say to try burping it now, but you already took it to the mechanic.
May 30, 2013 - 4:33 PM
Good news!! Apparently the radiator cap I bought was faulty and it just needed a new one. That's what I get for buying cheap parts.
May 30, 2013 - 6:38 PM
HUZZAH!!!
May 30, 2013 - 6:40 PM
Glad it is a small fix!
Jun 23, 2013 - 7:48 PM
yup was just about to say, its usually a problem with the radiator cap or head gasket leaking. just did a radiator cap fix a few months ago because of overflow. those gaskets tend to thin out over time and get smushed and cannot sustain the right pressure.
This post has been edited by trdproven: Jun 23, 2013 - 7:48 PM -------------------- 94 Celica GT
| Lo-Fi Version | Time is now: August 27th, 2026 - 2:22 PM |
