> Engine swap not starting!! Need help ASAP, HELP!! Emergency!
post Jun 4, 2013 - 10:31 AM
Reimrod1994
Joined Feb 21, '13
From saskatoon
I have a 1994 gt-s and a 1998 gt the 1994 is an american car and the 1998 is a canadian car, the 1994 is obd 1 and the 1998 is obd 2, i took the motor and wiring harness out of the 98 and put it into my 94, the wiring harness from the obd 2 motor plugged right into my obd 1 ecu no wires or anything left over, after getting everything hooked under the hood i filled it up with fresh fluids, now here is the problem..... Got in the car and i turned the key over and it just spins nothing happens, i checked the fuel filter and its dry, i tried pumping the gas and what not, i cant even hear the fuel pump running when i turn it to acc, so i pulled one plug out with a wire and there is no spark.. Anybody got ideas to what could cause this? Do i have to change over the ecu? Because the 1998 gt is a complete parts car would changing the ignition control module do the trick? I need any help i can get. I need this car running by the end f the day or my dad said hes ripping it out of the shop tomorrow with the truck even if its on jack stands.....
Replies (1 - 7)
post Jun 4, 2013 - 11:26 AM
cyberblader1130
Joined Oct 24, '09
From Appleton, Wisconsin 54915
Correct me if im wrong but if you used the OBD2 wiring harness, the motor + all the sensors youll need the OBD2 ECU so it can properly monitor the sensors that aren't on the OBD1 motor.
I would try the ECU from the newer car since you already have it.
post Jun 4, 2013 - 2:31 PM
Reimrod1994
Joined Feb 21, '13
From saskatoon
okay im not very sure what all the ecu is... just where i plug my wiring harness into? and would i have to switch over the ignition control module aswell? or anything else?
post Jun 4, 2013 - 4:57 PM
Reimrod1994
Joined Feb 21, '13
From saskatoon
i swapped out the ecu and nothing changed, no fuel coming and no spark still frown.gif is there something that i could have forgotten to hook up that could cause these two not to work?
post Jun 4, 2013 - 5:09 PM
richee3
Joined Jun 29, '08
From Denver
Attached to the ECU, there should be a small relay, the Circuit Open Relay or COR. It sends the signal for the fuel pump, I don't know about spark though.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 5, 2013 - 11:47 PM
Reimrod1994
Joined Feb 21, '13
From saskatoon
i changed the relay and still nothing... i really dont know what to do, i have un plugged and re plugged everything from the wiring harness twice... opinions?
post Jun 6, 2013 - 7:54 AM
bsamps4
Joined May 16, '10
From Raleigh
Check the EFI main relay and the 15amp ST fuse, as well as the starter relay. You should hear a click from EFI main when you cycle the key to ACC.
post Jun 7, 2013 - 2:42 PM
Reimrod1994
Joined Feb 21, '13
From saskatoon
QUOTE (bsamps4 @ Jun 6, 2013 - 7:54 AM) *
i am hearing a click, byt still no fuel or spark, everything on the car worked perfect on the car before i started like its a mint car
Lo-Fi Version Time is now: August 24th, 2026 - 10:19 PM
