> change struts?
post Jun 13, 2013 - 3:42 PM
momentai99
Joined Nov 19, '12
Guys how hard is it to change the rear struts in these cars? its keeping me from passing inspection although they look fine to me. Little bounce but I dont see an issue with them. Got quoted 600 bucks to change them from a local guy, screw that.
Replies (1 - 6)
post Jun 13, 2013 - 3:52 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
It should be an easy task. Probably get the rear done in a couple hours tops. The hardest part imo would be lifting the car up. Lol!
post Jun 14, 2013 - 3:30 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
The hardest part is changing the springs over from the old strut to the new one, and rusty bolts if thats an issue.
It'll probably cost you around 200 bucks for the struts (based on what i paid in canada, probably cheaper in the us) and few hours labour to change if you don't know what you're doing.
Check the stickies, theres a solid write up on installing lowering springs, which is essentially the same process as changing struts.
This is what I followed when I did mine, and had no idea what I was doing.
Its pretty simple, 3 14mm(i believe) nuts on the top of the strut, 2 15mm bolts on the bottom of the strut to the knuckle, and then 3 nuts on the brake lines that hold them to the strut. (Don't remove in that order, however)
Once the strut assembly is removed, you simply loosen the top nut, compress the spring and then remove the strut mount. Pull your spring off along with the rubber insulator, and put that assembly on the new strut. Throw the top mount on, and bolt it back up and throw it back in the car.
Lots of info here on how to do it!
My Celica!
post Jun 14, 2013 - 9:53 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
The rear struts don't use as much compression for the springs like the front. Most times you can get away without even using a spring compressor when you loosen the top nut and the springs can move somewhat freely in the strut assembly. If you put the rear on jack stands you can do the job pretty quick.
post Jun 15, 2013 - 3:05 PM
momentai99
Joined Nov 19, '12
Sounds like it wouldn't be that difficult then. Good to know, ill probably be attempting it this weekend.
post Jun 17, 2013 - 1:09 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
If youre going to do it without spring compressors, id do it at your own risk.
I used spring compressors all around, just to be safe.
My Celica!
post Jun 17, 2013 - 2:08 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (jordisonjr @ Jun 17, 2013 - 11:09 AM) *
+1, I believe you can loan one from your local auto parts store.
Lo-Fi Version Time is now: August 26th, 2026 - 9:28 PM
