> 3S-GE gen 2 swap, how hard is it?
post Jun 16, 2013 - 10:11 AM
Eric_Mark_X
Joined Jun 16, '13
From The Hague
Hey guys, I'm new here and I have a question.
Is it possible and how hard is it to swap a 2nd gen 3S-GE engine, which came out of a 5th gen Celica
into a 6th gen which has a 7A-FE engine?
I searched the forum for quite a while, but i couldn't find anything about it.
Any answer would be appreciated.
Eric.
Replies (1 - 3)
post Jun 16, 2013 - 10:59 AM
richee3
Joined Jun 29, '08
From Denver
It is possible. The swap would be very similar to a 7a-3S-GTE swap. You'd need a new trans, axles, 3 new motor mounts, wiring harness work, etc. Depending on the cost of the motor, it wouldn't really be worth it for ~160 hp.
Edit: Meant to add, for a very very similar cost and amount of work, you could drop a V6 in your engine bay, have 200 hp and a mountain of torque.
This post has been edited by richee3: Jun 16, 2013 - 11:08 AM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 16, 2013 - 1:10 PM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
IF you want a 3sge, stick to the same gen as your car, the 3rd gen 3sge. Wiring will be much easier and give better power
JDM ST205
post Jun 16, 2013 - 7:02 PM
Eric_Mark_X
Joined Jun 16, '13
From The Hague
Thanks. I will stick to third Gen then. I noticed that the gen2 engines were a lot cheaper. I guess its for a reason.
Topic can be closed.
Lo-Fi Version Time is now: August 31st, 2026 - 3:03 PM
