> EGR valve, EGR test?
post Jun 19, 2013 - 1:28 PM
cwong
Joined Jun 8, '13
From goldsboro, NC
Anybody know how to test if the EGR valve is properly working or the EGR valve modulator
Replies (1 - 3)
post Jun 19, 2013 - 11:39 PM
IfWeChoose
Joined May 25, '13
From Charlotte, NC
1989-95 ENGINE PERFORMANCE
Toyota EGR Function Testing
All Models
EGR VALVE
1) Disconnect vacuum hose to EGR valve. Using a hand-held
vacuum pump, apply vacuum to EGR valve with engine at idle. Engine
should run rough or stall. If engine does not run rough or stall,
check EGR valve passages for blockage or faulty EGR valve. Clean
passages as necessary. If passages are clear, replace EGR valve.
2) Install vacuum gauge to ported vacuum port to EGR. Raise
engine RPM. Vacuum should be present. If vacuum is not present, clear
vacuum port of blockage.
post Jun 19, 2013 - 11:46 PM
Julian_Navia
Joined Nov 10, '11
From Rockville, MD
Pull off the valve suck on the top and have someone look at the valve while you do it to see if the valve is still functional
Normally if it has any sort of blockage youll see it as soon as you pull it off
This post has been edited by Julian_Navia: Jun 19, 2013 - 11:47 PM
Dude I almost had you
post Jun 21, 2013 - 1:52 AM
cwong
Joined Jun 8, '13
From goldsboro, NC
Thanks guys
Lo-Fi Version Time is now: September 2nd, 2026 - 1:12 PM
