> WTB: JDM Projector Low-beam side light plug/harness
post Jun 19, 2013 - 10:42 PM
DKGT4
Joined Sep 25, '09
From Edmonton
Hey guys, I am looking for the plug for the side light in the JDM projectors... The projectors I got didn't have them. Makes me sad. The part that I am looking for is not the piece that holds the bulb, it is the plug that connects to that.
If you do not understand... I can try to explain more.
Thanks in advance!
Replies (1 - 2)
post Jun 20, 2013 - 12:42 AM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
So you're missing the two accent plugs? Or are you talking about the wire that actually connects to the plugs? If you are then, you won't get them with the projectors. You'll have to make your own. They came stock connected to the wire harness on the celicas that came stock with the projectors only. If your car didn't come stock with the projectors. Then you'll have to make your own.
post Jun 20, 2013 - 3:43 AM
azn87
Joined Aug 2, '06
From bay area
I had went to the junk yard looking for different 194 plugs and just cut them, then test fitted them on the headlight and splice my side marker for power!!
Lo-Fi Version Time is now: August 23rd, 2026 - 4:46 AM
