Jun 21, 2013 - 12:47 PM
Enthusiast Joined Feb 12, '12 From Norway Currently Offline Reputation: 0 (0%) |
Hi there all fellow celica owners (or pre-owners)
I have encountered a annoying problem with my lights on my toyota celica. The headlights and the fog lights suddently gave up on me, this is a Norwegian car, so the park lights go on when i turn on the ignion. But when I flick the switch for the normal lights, the headlights will not come on, howere, I can still use the "high beam" lights. The fog lights don`t respond either if I try to switch them on. I don`t think the fuses are bursted. I tried to swap them. When I turn the switch I can here that the relay flicks in the engine room. Have someone encountered the same problem before? Is there any electrial drawings/schemes online (edit: found the electrical drawings)? This is a Celica 1.8 T20 1998 modell. best regards This post has been edited by celicaNOR: Jun 21, 2013 - 12:49 PM |
Jun 21, 2013 - 1:14 PM
Recently had a similar issue on my Murano. The relay was clicking but it was still broken. Try swapping your low beam and high beam relays to see what happens.
Jun 21, 2013 - 4:35 PM
Thanks for the advice, I will start troubleshooting first thing in the morning. Just wanted to hear if there were other owners witch have encountered the same problem.
Jun 22, 2013 - 3:40 AM
Well, I tried to swap the relay for the high beam and low beam headlights. That didn`t work. So I tried to swap the fuses also, that didn`t work either.
The strange thing is, when I took out the relay for the low beam headlights and turned on the high beam. The fog lights came on, it wasn`t very strong, it was simiular to a 5W light booble. |
Jan 4, 2015 - 3:44 PM
Enthusiast ![]() Joined Nov 29, '07 From california, marysville Currently Offline Reputation: 0 (0%) |
Did you ever solved the probelm? My celica is doing the same thing... I'm driving around with my high and low beam connectors switched around
Jan 5, 2015 - 1:33 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
![]() ![]() ![]() also: https://workspaces.acrobat.com/app.html#d=n...dQxmOSlbtG2Hqpg This post has been edited by azian_advanced: Jan 5, 2015 - 1:46 AM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
| Lo-Fi Version | Time is now: August 26th, 2026 - 9:27 PM |
