> Auto GT swap into manual ST. Similar trans?
post Jun 27, 2013 - 10:34 PM
davidaus
Joined Oct 1, '12
From winnipeg,mb,canada
Theres a 1995 6g gt up for auction and i want to use the motor out of it in my st but, i need to know if the 7a-fe manual trans can bolt up to the 5s? Also how would the swap go because the 5s auto uses a tcu with the ecu which means i would have to depin and move around some things for the swap right? Thanks guys! here's the link for the 6g gt auction car: http://apps.mpi.mb.ca/salvage/SlvgItmImg.a...6&itemnm=69
Replies (1 - 3)
post Jun 27, 2013 - 10:47 PM
Box
Joined Feb 23, '12
From Warrior, AL
Nope. The A series engines use C series transmissions. The S series engines use S series or E series transmissions. If you want a 5 speed GT just buy one and then sell your ST.
2001 Miata LS 5-speed
post Jun 27, 2013 - 10:48 PM
if you swap the engine, swap the trasmission, and drive 5 speed!!! unless its an auto, swap all
post Jul 3, 2013 - 3:52 PM
davidaus
Joined Oct 1, '12
I ended up buying it for $600 and its a california car! Absolutely clean body, I'm pretty pumped for the swap. Thanks guys.
Lo-Fi Version Time is now: July 6th, 2026 - 2:02 AM
