> HELP!!!!!, Tach gone scycho
post Jan 24, 2004 - 7:49 PM
Uriel
Joined Sep 28, '03
From Brighton, MI
Ok, I need some SERIOUS help here guys. I went out side this morning before work to worm up my car. after it ran for a few the check engine light came on (UH OH) confused.gif i thought WTF and checked around a bit but evenually had to head off to work. As i was driving down the road (light still on mind you) my Tachometer started to fluctuate. as in it moved up and down rapidly and randomly.ALL OVER THE PLACE!! frown.gif but it didn't effect the engine itself (drove ok). I was worried about it all day at work....finally left wrok and it did it again!! AHHH, but this time it DID effect the engine. The engine basically mimicked the tach's movements (barely made it home). Also while i was trying to make it home, the check engine light (which was still on) started to blink for a bit (maybe 6-8 blips) then went constant again. PLEASE, if anyone has ANY idea of what this might be, let me know. I can't afford to lose my baby. I would GREATLY apprieciate it.
~Chris
post Jan 25, 2004 - 11:26 AM
celicarocker
Joined Sep 25, '03
From cranston RI
wow.... i have never seen that happen before, so i can't offer much advise, but the best of luck to you...
post Jan 25, 2004 - 12:23 PM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
You need to take it to a shop and have someone see what code the computer is setting to turn on the check engine light. As far as the tach prob, i have never heard of anything like that, hopefully its related to the check engine.
post Jan 25, 2004 - 1:41 PM
My speedo started doing that, all over the place. I would be driving 30miles an hour and it'd be pinned at 150 or something. After the swap tho it stopped so i think it had something to do with the sensor.
post Jan 25, 2004 - 2:49 PM
celicarocker
Joined Sep 25, '03
From cranston RI
QUOTE (Supersprynt @ Jan 25, 2004 - 6:41 PM)
the speedo in my old car (91 lebaron convertible) would do that all the time, then go down to zero and stay there... never bothered to get it fixed...
post Jan 25, 2004 - 9:18 PM
Einhander
Joined Oct 23, '03
From ky
Your tach will do that from a bad ground or bad connection. As far as the motor i have no clue there. . . .Def pull the code and go from there.
post Jan 27, 2004 - 12:47 PM
97GTinKC
From KC
since it is affecting the engine, I'd lean towards an ignition coil prob, (or a bad ground ) best to get the codes read, some parts stores will do it for free, hoping to sell you the part it points out.
post Feb 12, 2004 - 1:59 PM
Uriel
Joined Sep 28, '03
From Brighton, MI
Hey guys. found the problem. It ended up being just a ground wire afterall. The engine prob, I have no idea what that was, but it hasn't happened since. thnx for the help guys! biggrin.gif
Lo-Fi Version Time is now: May 26th, 2026 - 7:15 PM
