> How to fix the EGR code!!
post Jul 4, 2013 - 7:44 PM
Toyo6g
Joined Jun 28, '13
From México
I just make the diagnosis and it gives me this EGR code... 7 flashes + 1 flash and is the only problem that the car has!! Don't know where to start!!!
post Jul 4, 2013 - 9:22 PM
Box
Joined Feb 23, '12
From Warrior, AL
Shove a paper clip into the harness of the EGR temp sensor, gets rid of the code. tongue.gif
It's either caused by:
EGR temperature sensor
EGR valve
EGR modulator
EGR solenoid
Have to test them all individually to find the cause of the malfunction.
2001 Miata LS 5-speed
post Jul 4, 2013 - 10:05 PM
Toyo6g
Joined Jun 28, '13
From México
Any
threads?
post Jul 4, 2013 - 10:52 PM
trdproven
Joined Aug 2, '05
From Guam
i got lucky for a few years now, i pulled out the EGR filter and cleaned it, erased the code, and never came back.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 4, 2013 - 11:56 PM
Toyo6g
Joined Jun 28, '13
From México
I alredy done that.... The filter is brand new and i erased the code after 25 min came back on....I think that I will remove TB and clean it! 8)!
post Jul 5, 2013 - 12:57 AM
trdproven
Joined Aug 2, '05
From Guam
EGR gets some gunk inside it too.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 9, 2013 - 7:19 PM
lambowannabe
Joined Jul 8, '13
From Atlanta
I used to have an EGR code too. I ended up fixing it by noticing a hose was disconnected under the hood. I think the previous owner must have taken off one the EGR system hoses.
post Jul 9, 2013 - 10:57 PM
Toyo6g
Joined Jun 28, '13
From México
Welll... The cable is in place!!! I think but after I clean the T.B the engine light turns off... The after an hour lights back again!! I think if I remove the T.B and clean everything this problem will be fix!!.... I hope!!
post Jul 10, 2013 - 12:23 AM
Box
Joined Feb 23, '12
From Warrior, AL
The way the code triggers is once it's up to temp and hits 55+ mph, if things aren't right it stores the code temporarily. The next time you drive and hit 55+ if the problem still exists it throws the code and triggers the light. The only thing that'll cause the EGR code are the things I mentioned in my first post.
This post has been edited by Box: Jul 10, 2013 - 12:23 AM
Lo-Fi Version Time is now: September 4th, 2026 - 11:06 AM
