> oil leak, oil pan? oil pump?
post Jul 18, 2013 - 5:15 PM
jeffp610
Joined Jul 18, '13
From Temecula,ca
So i got a 95 celica gt, with 2.2l engine, i was backing up this morning and notice an oil leak spot on my driveway, and was trailing. it seems to be coming from the oil pan gasket, but near where the front oil pump meets the engine, plus it leaks oil continously when running? so im guessing the oil pump seals? oh yeah the car is a high mileage car.. im planning on engine swap but not anytim soon since the engine still runs strong and compression still good accross.
can i just go by replacing all the gasket and seals, or should i replace the oil pump and all the seals? and does anyone have a write up on diy??
Replies (1 - 3)
post Jul 18, 2013 - 5:52 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
replace all the seals. and be extra careful with replacing the oil pump seals. they are very thin.
エキサイティングカーレーシングチーム!
post Jul 18, 2013 - 6:19 PM
jeffp610
Joined Jul 18, '13
From Temecula,ca
QUOTE (Tigawoods @ Jul 18, 2013 - 5:52 PM) *
But i should be good without replacing the oil pump itself right? as long as there's no weird noises and im not losing oil pressure..??
and any specific brand i should use? or can i just go to local autozone,o'reilly's and pick one up?
post Jul 18, 2013 - 7:31 PM
6G96GT
Joined Jan 20, '08
From East Coast
http://www.6gc.net/forums/index.php?showto...mp;#entry992473
That was a leak I had which ended up being the oil pump seal.
Lo-Fi Version Time is now: August 11th, 2026 - 5:08 PM
