> Smoke coming out of tail pipe
post Jul 19, 2013 - 6:39 PM
Jules88
Joined Dec 19, '12
From California
So I posted on here several months ago and received some pretty good advice, but now I'm having different problems.
I have a '94 Celica ST automatic, with a rebuilt '94 Corolla 1.6 engine in it. Well some parts are from the Corolla, some are from the Celica. We finally put it all together and now it runs, but I'm having the SAME problem I had with the old engine - grayish smoke coming out of the tail pipe. I know oil is burning and I probably should have changed the rings and pistons, but could it be caused from anything else? Or is it a coincidence that both engines are giving me the same problem? The old engine broke down on the freeway - a piston shot through it creating 2 large holes. So I got a different engine from Pick A Part. I know it probably won't pass smog at this point, but I'm just wondering if anyone has any advice on what I can do to minimize the amount of smoke coming out, etc. Someone mentioned checking the spark plugs for oil then gapping them, and doing a transmission flush, and using synthetic oil or some kind of additive, Marvel Mystery Oil, etc. Give me your thoughts on this, I will try everything possible before spending money on rings and pistons. I appreciate all comments. Thanks!
[size="3"][/size]
post Jul 19, 2013 - 6:50 PM
rentaspace
Joined Sep 23, '12
From Australia
Could try the PCV valve, that could cause some smoke if its got oil in it
post Jul 19, 2013 - 10:35 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
it could be a clogged PCV. you did put a used engine in so you have no idea what the history on it is. I have a freshly build 7A-FE for sale in about a week. where in CA are you? im in Los Angeles area. if you are local and interested in this engine, let me know i can even install it for you alot cheaper than anyone else
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 20, 2013 - 6:59 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (Smaay @ Jul 19, 2013 - 8:35 PM) *
+1, if I was to ever do a swap. I'd take it to smaay. Lol.
post Jul 20, 2013 - 7:36 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
If your exhaust was loaded with oil it could still be burning off.
post Jul 21, 2013 - 12:17 AM
Jules88
Joined Dec 19, '12
From California
QUOTE (Smaay @ Jul 19, 2013 - 11:35 PM) *
Yeah the PCV was taken off so it's not that. He might take the exhaust pipe off to see if it's just old oil burning off.
Smaay, thanks for offering. I'm not far from LA, I'm in Riverside. How much are you selling it for? I wouldn't need help installing it, but buying that engine would definitely solve my problem. lol. I'm new to this forum so I don't know how to private message you, so message me if you want.
Thanks.
This post has been edited by Jules88: Jul 21, 2013 - 12:17 AM
post Jul 21, 2013 - 3:56 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
i sent you a PM
Lo-Fi Version Time is now: June 22nd, 2026 - 5:52 PM
