> Fribox's 1996 Celica GT, A used car that likes to suck money out of my pockets
post Jul 19, 2013 - 7:40 PM
fribox
Joined Jul 14, '13
From Stow, Ohio
5s-fe, 5 speed, 221000 miles. Second owner. (Now nearing 225000)
It looks shiny in this picture, but it has a lot of problems.
Engine refuses to rev past 4500-5000 RPM (not that I do this often), if anyone has a solution to this I'd be very grateful. I've read a bit on here its either the catalytic converter being clogged or timing is off.
This thread isn't really much of a project thread, more of a maintenance diary. I don't plan anything spectacular with this car, but I'd like to share my woes and experience with you guys.
Maybe I'll come across something and find out what is wrong and help someone who has the same problem, who knows.
I was first planning a 3S-GE swap, but figure its not worth the hassle on a car with 225000+ miles on it. I've seen good things about 294 grind cams though, which is what I might do for the little more umf at the high end that I want.
But I'll post whatever happens to my car here.
This post has been edited by fribox: Mar 18, 2014 - 10:38 PM
- fribox   Fribox's 1996 Celica GT   Jul 19, 2013 - 7:40 PM
- - richee3   The 5S is known for valve cover gaskets leaking. I...   Jul 19, 2013 - 7:59 PM
|- - fribox   QUOTE (richee3 @ Jul 19, 2013 - 7:59...   Jul 19, 2013 - 8:31 PM
- - richee3   On the plus side, you have a new timing belt! ...   Jul 19, 2013 - 9:38 PM
|- - fribox   QUOTE (richee3 @ Jul 19, 2013 - 9:38...   Jul 19, 2013 - 11:36 PM
- - Box   Generally when the distributor goes out it'll ...   Jul 20, 2013 - 12:05 AM
- - fribox   Alright, gave revving it in neutral a try. Interes...   Jul 20, 2013 - 4:47 PM
- - Box   It's as if it's in a limp mode. Is the ch...   Jul 20, 2013 - 5:15 PM
|- - fribox   QUOTE (Box @ Jul 20, 2013 - 5:15 PM)...   Jul 20, 2013 - 7:16 PM
- - fribox   Did cap today, seems to run a bit better. Far less...   Jul 24, 2013 - 5:59 PM
- - fribox   Roof rust fixed, door rust fixed, dents pulled, ch...   Aug 17, 2013 - 12:27 PM
- - Box   Yay new paint!   Aug 17, 2013 - 1:57 PM
- - fribox   Moar pictures. Never fixed that headlight, I shoul...   Aug 17, 2013 - 9:02 PM
- - Box   Might as well just get projectors at this point.   Aug 18, 2013 - 10:52 PM
- - fribox   <snip> EDIT: Taking it to a shop tomorrow, ...   Aug 27, 2013 - 12:47 PM
- - fribox   Dropped the new radiator in. (I'll get a pic u...   Sep 5, 2013 - 12:49 AM
- - JoshuaM   Whoa, close call! P.S. We WILL disown you if ...   Sep 17, 2013 - 12:00 AM
- - cheela   QUOTE (JoshuaM @ Sep 17, 2013 - 12:0...   Sep 17, 2013 - 8:27 AM
- - fribox   Haha, Thanks guys. I've been away for some tim...   Oct 29, 2013 - 9:19 PM
- - fribox   Update: Turns out that miss-firing/wobbling/whatev...   Nov 23, 2013 - 12:09 PM
- - fribox   Hey, posting another update. The front engine moun...   Jan 11, 2014 - 3:54 PM
- - Tigawoods   you should throw in the poly urethan motor mount i...   Jan 11, 2014 - 5:22 PM
|- - fribox   QUOTE (Tigawoods @ Jan 11, 2014 - 5...   Jan 11, 2014 - 6:04 PM
- - fribox   -snip- I changed the oil last weekend and the eng...   Mar 18, 2014 - 10:29 PM
- - sandusky1977   I've got wood and see it in maybe 5% of the ti...   Mar 18, 2014 - 11:20 PM
- - njccmd2002   Nope its not rare most people like me, yanked it o...   Mar 19, 2014 - 3:09 AM
- - mkernz22   Those wheels are the stock bbs option, which isn...   Mar 19, 2014 - 9:22 AM
|- - fribox   QUOTE (mkernz22 @ Mar 19, 2014 - 9:2...   Mar 19, 2014 - 8:22 PM
- - ClevelandGaint   If you need any help with swaps or questions with ...   Mar 19, 2014 - 11:09 PM
|- - fribox   QUOTE (ClevelandGaint @ Mar 19, 2014 - 1...   Mar 20, 2014 - 10:51 PM
- - fribox   New shifter cable bushings arrived. I've done ...   Mar 26, 2014 - 2:19 PM
- - richee3   I don't know that there is a writeup for these...   Mar 26, 2014 - 2:28 PM
|- - fribox   QUOTE (richee3 @ Mar 26, 2014 - 3:28...   Mar 26, 2014 - 2:39 PM
- - richee3   Yours are definitely a lot worse than mine were th...   Mar 26, 2014 - 2:45 PM
- - fribox   Both the shifter bushings were rusted to the mount...   Mar 27, 2014 - 10:40 PM
- - fribox   Just ordered a set of these since I couldn't f...   Apr 1, 2014 - 1:24 AM
- - fribox   Hey, wow, it took forever for these to get here + ...   Apr 21, 2014 - 1:52 PM
- - fribox   Replaced the preconverter. It was reading ~10psi w...   Sep 20, 2014 - 2:14 PM
Lo-Fi Version Time is now: September 13th, 2026 - 12:40 AM
