> NEED Help, Car troubles tryin to turn on
post Jul 21, 2013 - 5:52 PM
marco-polo
Joined Nov 13, '08
From San Antonio, Tx
i got a 94 stock gt with 204k. the problem is when I let the car sit overnight or for a couple of hours its a real problem to turn it back on. I cant figure out exactly what it is.
My story is the distributor, plugs, wires fuel pump and filter are about 2 1/2 yrs old.
I thought it was ignition coil cuz I was doing some researching on here and replaced it. Still having same problem, fuel pump still primes when you turn key and fuel is still passing through filter. I know its a fuel problem because when I turn the key the car wants to turn on and if I press the gas pedal as if I was reving it the car barely turns on and stutters at first but then idles fine, she then runs fine, if I turn off car then turn it back on there is no problem. its only when it sits for a while and cools off.
** over the past week I cleaned the iacv and TB....but problems started before that's why I cleaned out TB area.
As well as seafoamed the car(1/3 thru vaccum less than 1/3 thru oil due to high miles, and more than 1/3 thru gas.).
- marco-polo   NEED Help   Jul 21, 2013 - 5:52 PM
- - ILoveMySilly97   So cold starts, it won't turn on unless you pr...   Jul 21, 2013 - 7:31 PM
- - marco-polo   That's right   Jul 21, 2013 - 8:02 PM
- - ILoveMySilly97   Any CEL? Could check the timing? Or reset the air:...   Jul 21, 2013 - 8:08 PM
- - marco-polo   No CEL...about to reset air/fuel   Jul 21, 2013 - 8:16 PM
- - Galcobar   Sometimes it can be something simple: check the in...   Jul 22, 2013 - 2:10 AM
Lo-Fi Version Time is now: July 11th, 2026 - 10:21 PM
