Jul 26, 2013 - 9:23 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
What is the connector under the seat for? Is it the seat belt tension reducer?
I found out today as I was cleaning that the wire snapped from the connector, how do I splice it back? Thanks -------------------- God made man....
Everything else... Made in China ![]() |
Jul 26, 2013 - 9:32 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
Airbag.
Jul 26, 2013 - 10:12 PM
Jul 26, 2013 - 10:37 PM
It's probably for the seat belt latch, tells the car the belt is in use or not. Anyhow the best way to fix it would be to solder it back in. If there isn't wire sticking out from the clip to easily solder to, you can try using solder paste in attempts of getting it back to together more easily. Worst case scenario you'll just have to use some other clips or directly wire it.
This post has been edited by Box: Jul 26, 2013 - 10:38 PM -------------------- 2001 Miata LS 5-speed
Jul 27, 2013 - 4:02 AM
It's probably for the seat belt latch, tells the car the belt is in use or not. Anyhow the best way to fix it would be to solder it back in. If there isn't wire sticking out from the clip to easily solder to, you can try using solder paste in attempts of getting it back to together more easily. Worst case scenario you'll just have to use some other clips or directly wire it. It broke off where the connector is. I disassembled the connector and I messed up the terminals where the wires are crimped. Does anyone know where I can get replacements for those metal pieces in the picture? Thanks
Jul 27, 2013 - 7:42 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '12 From Brisbane, Australia Currently Offline Reputation: 6 (100%) |
+1 on the seat belt warning. I took my seat out today and forgot about the cable.... felt the tug just soon enough before I ripped it out of the car though With something that small it might be eaiest just to pay a couple of bucks for a new connector from Toyota? Or as Box said, you can just cut both plugs off and solder on a new plug pair -------------------- ![]() SOLD :( 1997 ST204 Celica ZR -----> See it here on 6GC! 2013 October Celica of the Month XD Now: '00 NB8B Mazda MX5 -----> See it here in off topic! |
Jul 27, 2013 - 1:12 PM
If it were me I'd just replace it with: http://www.ebay.com/itm/nCP-X-Battery-conn...=item4171f18000
Problem solved for under $3 and it maintains the ability disconnect easily only when you want it to. Even looks OEM. -------------------- 2001 Miata LS 5-speed
| Lo-Fi Version | Time is now: July 7th, 2026 - 1:36 PM |
