> New engine badge, Making your own badge
post Jul 29, 2013 - 12:37 PM
kevH
Joined Aug 30, '12
From New Jersey
Hi, figured I'd post this if it helps someone out. Couldn't find a new '16 Valve' badge so ended up making my own. Basically removed the old badge with a thin blade, it's plastic so it bends and wasn't too concerned with breaking it. Scanned it in to get size, then edited the scan with the new font, I know it's different but I really liked this one particular font in my toolkit.
Printed multiple copies out in high resolution on printable transparent sheets that are inkjet compatible (see picture, white labels are printed item)
Bought thin aluminum sheet from hobby store, cleaned surface, stuck on sheet and trimmed around with tin snips. Lightly sanded edge to remove sharp edge. Used double sided decal tape on back.
Finally, sprayed with high temperature clearcoat to protect ink.
Cost was about $8 for sheets, $2 for aluminum sheet and couple of bucks for the tape. The clearcoat was $8 but I figure I'll spray other things on the engine.
http://s1277.photobucket.com/user/kghareus...b5552f.jpg.html
Update:- Here's how it looks on the engine, note, the heat shield is still horrible, we're working on that next.
http://i1277.photobucket.com/albums/y494/k...zpsc457b271.jpg
This post has been edited by kevH: Jul 30, 2013 - 6:46 PM
post Jul 29, 2013 - 11:19 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
I've had decent results with the 3M trim tape and heat. I have a vintage Toyota emblem on my oil cap that is held on by that tape and no issues yet. The cap also gets too hot to hold on to.
post Jul 30, 2013 - 10:35 AM
kevH
Joined Aug 30, '12
From New Jersey
Thanks, that's the tape I have so good to know it will handle heat.
Lo-Fi Version Time is now: August 28th, 2026 - 9:45 PM
