Aug 2, 2013 - 12:40 AM
Enthusiast ![]() ![]() ![]() Joined Nov 4, '09 From Sacramento, California Currently Offline Reputation: 0 (0%) |
Hey everyone, it's been a long time since my last post. Car still runs beautifully but my first ever problem arose that perhaps a friendly user might help me solve, or know of the page that solves it.
So my coolant has been boiling out of the reservoir after driving on the freeway and coming to a stop. I tried changing the thermostat, maybe the thermostat is defective? Well assuming it's not (I do plan on going back to the dealership and asking for a new one in exchange however) perhaps it may be something else. Does anyone know where the sensor to monitor the temperature of the coolant before the radiator fan kicks in is? I'm having trouble searching for it, but I figured that if I change the sensor and the thermostat (again) then maybe my problems would be solved. Also if anyone has any idea as to why it continues to do this, with all appreciation I urge you to please respond. Thank you and much love, Rafael. Edit: check last picture to see the new situation This post has been edited by HaysoosKreesto: Aug 16, 2013 - 10:16 AM -------------------- Brand new 6gc owner! (sort of 2011)
The world is moving around a sun, the sun moves around a local arm of the galaxy, the local arm of the galaxy moves around a gigantic black hole. |
HaysoosKreesto coolant and thermostat question Aug 2, 2013 - 12:40 AM
Box If it's like the 7A it'll be on the driver... Aug 2, 2013 - 1:46 AM
ILoveMySilly97 QUOTE (Box @ Aug 1, 2013 - 11:46 PM)... Aug 2, 2013 - 4:38 AM
nics internal leak, my .02 Aug 2, 2013 - 10:56 AM
Toyo6g I had the same problem.... Blown head gasket!... Aug 2, 2013 - 12:12 PM
Box It could be a variety of things. First thing I... Aug 2, 2013 - 1:39 PM
Galcobar All of the sensors and fan switches can be tested ... Aug 2, 2013 - 9:06 PM
HaysoosKreesto QUOTE (Box @ Aug 2, 2013 - 1:46 AM) ... Aug 3, 2013 - 1:50 PM
ILoveMySilly97 QUOTE (HaysoosKreesto @ Aug 3, 2013 - 11... Aug 3, 2013 - 2:19 PM
HaysoosKreesto Thank you all for helping a poor fool like I, much... Aug 3, 2013 - 1:53 PM
perkyshadow I had the same issue in my old 5s. When I changed... Aug 4, 2013 - 9:14 PM
Box Autozone should have a compression checker in thei... Aug 4, 2013 - 9:41 PM
HaysoosKreesto Well on further inspection after work today I THIN... Aug 6, 2013 - 11:30 PM
Box Well, there's your problem. Glad it was an e... Aug 6, 2013 - 11:33 PM
HaysoosKreesto QUOTE (Box @ Aug 6, 2013 - 11:33 PM)... Aug 6, 2013 - 11:41 PM
HaysoosKreesto This giant crack appeared on the radiator today, l... Aug 16, 2013 - 10:18 AM
Box Same thing happened to me, I coated it in epoxy an... Aug 16, 2013 - 2:42 PM
Syaoran I'd go with a full aluminum radiator. Tt has n... Aug 16, 2013 - 4:10 PM
ILoveMySilly97 QUOTE (Syaoran @ Aug 16, 2013 - 2:10... Aug 16, 2013 - 4:30 PM
Box You can weld plastic too technically. The only pr... Aug 16, 2013 - 4:51 PM
Bitter I was reading down the thread and thinking 'ba... Aug 16, 2013 - 7:55 PM
HaysoosKreesto QUOTE (Bitter @ Aug 16, 2013 - 7:55 ... Aug 27, 2013 - 11:58 AM![]() ![]() |
| Lo-Fi Version | Time is now: May 17th, 2026 - 9:15 PM |
