> FS: AC Delco inner tie rod ends.
post Aug 9, 2013 - 4:31 PM
richee3
Joined Jun 29, '08
From Denver
I have two extra 15 mm wheel spacers I don't need. I do not have any extra studs to go with them, only the spacers. Open to offers.
AC Delco inner tie rod ends. Brand new in box, never opened. Rock Auto apparently sent a set to me and a set to my parents' house. Cost $80 shipped, don't need them at all. Not looking to get my money back. My loss is your gain.
This post has been edited by richee3: Oct 19, 2013 - 8:19 PM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
Replies (1 - 19)
post Aug 9, 2013 - 4:55 PM
jesse09
Joined Jan 19, '09
From Texas
PM'd
post Aug 9, 2013 - 5:08 PM
PegGTS
Joined Apr 15, '13
From Winnipeg, MB, Canada
Don't really know much about spacers lol but do you think I could use them on my back wheels?
2007 Impreza 2.5i - Daily
1994 Camry - Sold
1994 Celica - Sold :(
Click here to see my progress thread!
post Aug 9, 2013 - 7:34 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (jesse09 @ Aug 9, 2013 - 4:55 PM) *
PM'd
Replied.
QUOTE (PegGTS @ Aug 9, 2013 - 5:08 PM) *
Yes. You'd just need to buy some extended wheel studs to go with these spacers since I don't have them. 10 mm isn't a huge spacer but they make a noticeable difference.
1998 Celica GT-
BEAMS Swapped.
post Aug 10, 2013 - 12:49 AM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (PegGTS @ Aug 9, 2013 - 3:08 PM) *
If you want to flush them out. I think you'll need 25mm+ spacers. Lol. You're better off with buying adapters/spacers. So you wouldn't need to install extended lug nuts and you can also get the ones that converts from 5x100 to 5x114. wink.gif
post Aug 10, 2013 - 9:08 AM
PegGTS
Joined Apr 15, '13
QUOTE (ILoveMySilly97 @ Aug 10, 2013 - 1:49 AM) *
Any specific reason to convert to 5x114? My wheels are 5 bolt universal so I technically could
1994 Camry - Sold
post Aug 10, 2013 - 1:13 PM
ILoveMySilly97
Joined Mar 8, '12
Since your wheels are universal then if I were I would get the adapter. 5x100 is really limited to aftermarket wheels. 5x114 opens your wheel market, double than what you'll find in 5x100 market. Lol. Its really hard to find a perfect set of wheels for 5x100. Like for me. I want the xxr 535 but they don't come in a low enough offset or wide enough rim for me to flush out with minimal use of spacers. So.....i might end up going with the 527 since they're universal.
post Aug 23, 2013 - 3:45 PM
richee3
Joined Jun 29, '08
From Denver
Bump. Also adding a Kirkosarus poly motor mount insert. Pictures still coming, if I can ever remember.
post Aug 23, 2013 - 4:13 PM
bnr32celica
Joined Jan 16, '12
From 860, ct
Which mount does it fit?
post Aug 23, 2013 - 4:18 PM
richee3
Joined Jun 29, '08
From Denver
Front and I think the rear too but don't quote me on that. I've had a front insert for over a year now and just bought a brand new pair so I can get the rear insert. I think the front and rear inserts are identical but they may not be.
1998 Celica GT-
BEAMS Swapped.
post Aug 23, 2013 - 5:00 PM
bnr32celica
Joined Jan 16, '12
From 860, ct
I would need the rear over the front with the 1MZ. I'll research it.
post Aug 24, 2013 - 4:27 PM
richee3
Joined Jun 29, '08
From Denver
Like I said, I think the front and rear are interchangeable but I'll be able to confirm that in a couple of days. Unless someone jumps in here and confirms it first.
Pics of the spacers!
Pics of the mount insert coming in the next couple of days.
1998 Celica GT-
BEAMS Swapped.
post Aug 26, 2013 - 12:26 PM
richee3
Joined Jun 29, '08
From Denver
Confirmed that the front and rear mount inserts are definitely different. Since I only need the rear, here are pics of the front:
1998 Celica GT-
BEAMS Swapped.
post Aug 26, 2013 - 3:15 PM
perkyshadow
Joined Nov 13, '10
From Greenville, SC
Man, I've been wondering how just one insert was beneficial. I had this idea that it was a single one, and not a set! Hahahaha! This makes so much more sense!
post Aug 26, 2013 - 4:03 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (perkyshadow @ Aug 26, 2013 - 3:15 PM) *
It is beneficial to have just one. It's that much less flex in the motor mounts. Granted, having a pair is more beneficial, but having just a single insert will still help. I've just had the front insert for the last year and I'm getting ready to add my new rear insert. Since I had to order a new pair to get a rear mount, I have an extra front mount that I don't need. It's the same insert in the pictures, just two different angles.
1998 Celica GT-
BEAMS Swapped.
post Aug 26, 2013 - 11:46 PM
dkdmonk
Joined Nov 23, '12
From Troy, IL
Please confirm the spacers are 10mm not 15 (picture looked a little thick).
Would you take $20 for spacers?
I already have some 10mm longer studs (uninstalled).
post Aug 27, 2013 - 2:23 AM
richee3
Joined Jun 29, '08
From Denver
I'll grab a tape measure tomorrow. I bought these from Diegohiga who said they were 15 mm. They are the same thickness as my 10 mm spacers I have on the car now. $20 will work though.
1998 Celica GT-
BEAMS Swapped.
post Aug 27, 2013 - 8:53 PM
richee3
Joined Jun 29, '08
From Denver
From the sounds of it, I have a spare set of AC Delco inner tie rod ends at my parents's house. Anybody need them? They cost $80 shipped from Rock Auto and I have no use for them. I have a set here and a set there, apparently.
1998 Celica GT-
BEAMS Swapped.
post Sep 1, 2013 - 6:52 PM
richee3
Joined Jun 29, '08
From Denver
Front mount insert sold, added brand new in box inner tie rod ends.
1998 Celica GT-
BEAMS Swapped.
post Sep 1, 2013 - 7:50 PM
gen6coupe
Joined Sep 13, '10
From Austin, tx
QUOTE (richee3 @ Sep 1, 2013 - 6:52 PM) *
hmmm.. $40 on the tie rod ends? also interested in your antenna... maybe we coudl work out shipping it together..
Lo-Fi Version Time is now: August 23rd, 2026 - 11:40 PM
