> Brakes Wear Unevenly
post Aug 25, 2013 - 3:51 PM
Maggie73
Joined Aug 13, '13
From Burleson
My daughter and bf did a break job on the 99 GT last night. They noticed that the back pads that were on it were worn at an angle.
When the new pads (wagner) went on the back, they only had one shim....once they went on, they still made noise (rubbing) on the test drive....so my bf greased the slider pins...they still make a little noise at low speeds.
Anyone have any idea what else could help?
post Aug 25, 2013 - 3:52 PM
Did you grease the rear of the pads where the piston makes contact? Otherwise, I'd wager at a seized caliper.
This post has been edited by SwissFerdi: Aug 25, 2013 - 3:53 PM
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Aug 25, 2013 - 4:03 PM
Maggie73
Joined Aug 13, '13
From Burleson
QUOTE (SwissFerdi @ Aug 25, 2013 - 3:52 PM) *
They didn't grease the rear of the pad....that could make the pads wear at an angle?
What do you mean by seized caliper...? The bf said the piston IS moving.
post Aug 25, 2013 - 4:28 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
grease????? dont you just put the 2 backing plates back where they were and put the pads back in and pop the clips back on?
isnt it more likely that you drove through a puddle with hot rotors, warped the rotors, and thats why the pads are wearing uneven
either that or the car is in need of a wheel alignment pretty bad?
Mike W
269awhp / 273ft-lbs
post Aug 26, 2013 - 12:57 AM
trdproven
Joined Aug 2, '05
From Guam
did you notice if it was difficult to press in the pistons? how are the slider pin lubrication? greasing the shims are more for squeak prevention.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 26, 2013 - 8:39 AM
Maggie73
Joined Aug 13, '13
From Burleson
QUOTE (delusionz @ Aug 25, 2013 - 5:28 PM) *
Easy killer, I just bought the car....I don't know if it was driven through water or not, but not since I have had it (a couple weeks).
It doesn't need an alignment.
post Aug 26, 2013 - 8:48 AM
mkernz22
Joined May 10, '10
From MA
The uneven pad wear is from the slider pins starting to seize up. The slider pins are different from the piston. Mine had the same exact problem, the insides were wearing more than the outsides and they were also wearing at an angle too.
post Aug 26, 2013 - 9:12 AM
Maggie73
Joined Aug 13, '13
From Burleson
QUOTE (mkernz22 @ Aug 26, 2013 - 8:48 AM) *
Did greasing the slider pins fix your problem? We did that and it definitely improved.
post Aug 26, 2013 - 9:32 AM
Maggie73
Joined Aug 13, '13
From Burleson
QUOTE (trdproven @ Aug 26, 2013 - 12:57 AM) *
Lower slider pin received new grease. The piston seemed to press in normally and we verified the piston came back out via normal brake use. I wonder if the top slider pin could be suspect. Anyone have experience with removing this pin since it does not have a bolt head on it?
post Aug 26, 2013 - 10:21 AM
mkernz22
Joined May 10, '10
From MA
QUOTE (Maggie73 @ Aug 26, 2013 - 10:32 AM) *
Both the front and rears have two slider pins. The one rear one is a bolt-on, which the rear caliper slides onto and the other one goes through the caliper and the bolt goes through that. That is the only that usually seizes up in the rear.
As for the front, they should just pull right out. If they won't twist or move and you can hit them out with a flathead and mallet, then it's most likely seized too.
Lo-Fi Version Time is now: August 23rd, 2026 - 7:04 AM
