> Poly Bushings,Megan Coilovers Front and Rear Installed!, also installed F&R end links as well
post Sep 2, 2013 - 12:39 PM
So this weekend, we overhauled Jenns suspension on her 94 GT, I figured I'd post about the install and some of the in's and out's of what went into doing it.
First, here is what we bought for the install.
  • Megan Racing "Street Series" Coilovers
  • Polyurethane Bushing kit Front and Rear
  • 2's r Us Front St185 Endlinks
  • Racing Beat Miata Rear Endlinks
  • New OEM Ball Joints
Jenn's car had Eibach "Sportline" Springs, and KYB GR-2 shocks that I actually had installed by a local shop litterally over 10 years ago now. (Its actually one of the first things I posted about here on 6gc!)
When I first had them installed, they worked well, and rode pretty good too, but over the years, the shocks got worn out, and all the mounts, ect started to clunk and creek like crazy.
The ride really started to kinda suck, especially as the milage piled up, and all the suspension bushings got really worn, which introduced lots of slop in the steering and basicly made the car not handle nearly as well as it should, especially with the 3rd gen 3s in there.
So, we went ahead, and ordered the front and rear bushing kit from poland thru a seller on ebay called gt4goodies. here is a link to his ebay store:
http://stores.ebay.com/gt4goodies
We also ordered the Megan Coilovers thru upscaleautomotive.com, who has a FS thread here, and the discount code in the thread still works as of a few weeks ago.
So on Friday night, we went over to Dustin & Steff's house, and started tearing into the rear suspension on the car, which because of the rust issues, was a real challange.
A few things to remember when taking all that stuff apart, is that #1, heat is your friend. If you have acsess to a torch setup, awesome. If not, your gonna have issues.
I went ahead and had steff order me all new hardware, knowing that we were gonna have to cut and break some bolts to get em out, and I was right...lol
The long bolts that go thru the hub in the rear very often will be seized up, and without torches, and sometimes a press as well, they just will not budge.
So, what I would suggest, is if your car is rusty, and you dont have torches, ect. just tear it down so that the rear trailing arms are attached to the hub, and drag that whole unit to a local garage, and ask them to remove the bolts. If I had to guess, they'll charge you an hr or 2 labor for it, and it'll be done.
Next up comes getting the bushings out and installing the new ones.
For the front, its just the 2 bushings in the a-arm, which are held in place with rings on the outside of the bushings, that hold them in place. as long as those rings are intact, you can just use a drill to drill out enough space to get a sawsall thru the bushing, cut the ring, and the whole bushing will just push right out.
then its just a matter of pressing the new bushings in, and reinstalling everything.
The rears can be alot trickier, depending on the year make and model of your celica.
From what Dustin and Steff have been able to figure out, it looks like the 96+ GT's, and "Sport suspension" St's have diffrent arms that the poly bushings wont fit into.
Before you do the install, its best to make sure you have arms with the replaceable bushings (you'll be able to tell once you have the bushings, and compare that to what your arms look like on the car)
and if not, you can get ST arms most of the time. I'm sure I'm screwing this up somehow, but dustin will back me up with the correct info in a future post im sure!
Anyway, lets get on to some pics, thats what we're all here for, right?!!?
So, since Dustin has some spare front A-arms, we just installed the bushings into those, and here is what we had once we were done and ready to install em.
Then we went to do my rears, and noticed that the rings that hold the bushing in place, had actually rotted and basicly desintigrated as we removed the bushings.
I had to chip and hammer that crusty stuff out, basicly ended up smashing the ends of the arms a bunch with a 3lb sledge to break up the crust, then used a metal die grinding bit, to clean up the holes
then installed the bushings in those:
once we got those all done, and did the same to the rear hubs, we had everything ready to install:
We installed the fronts first:
Then installed the all the arms on the rear subframe
And reinstalled everything in the rear
Once everything was all reinstalled, we spent a little time adjusting the height of the car with the coilovers, and got it close enough to let everything settle in for a few miles.
Now its just a matter of driving the car, and playing with the damper settings till we find our sweetspot
The initial impressions are amazing.
First off, the car really does handle like a whole new car, everything is nice and tight, very responsive, the bushing kit makes the car feel so smooth and predictable, its really great.
The coilovers are really nice, small adjustments of 2-3 clicks actually make a diffrence that you can feel, everything is just awesome about them in every way.
over the next couple days I'll play with it some and get a better feel for everything overall and make a nice detailed post about it.
I do wanna just take a minute, and say thanks to my best friends, dustin (batman722) and steff (hurley97), there is no way I would have gotten all of this done without they're help, they really came thru in a huge way, especially steff, she actually took the rear hubs, with the arms connected to work, and had one of the techs there take the time to get those bolts out and clean up the holes for me, which saved me a bunch of money, time and effort!
- presure2   Poly Bushings,Megan Coilovers Front and Rear Installed!   Sep 2, 2013 - 12:39 PM
- - Fate   Great write-up as expected, hoping to do the same ...   Sep 2, 2013 - 2:03 PM
- - JaySee   Nice man, how do the Megans ride? im looking to ge...   Sep 2, 2013 - 2:37 PM
- - Syaoran   Makes me wanna re-do my suspension haha. What...   Sep 2, 2013 - 6:22 PM
- - ILoveMySilly97   Damn. Love the paint color!   Sep 2, 2013 - 6:34 PM
- - richee3   I think my '98 GT may not have the Sport suspe...   Sep 2, 2013 - 8:36 PM
- - Batman722   That's how we roll bro ! Glad you're h...   Sep 2, 2013 - 8:52 PM
- - fatherof4   Great Job! What was the total cost?   Sep 2, 2013 - 9:26 PM
- - playr158   Sweet Deal! I still have to do my rear bushing...   Sep 3, 2013 - 11:03 AM
- - adonzo   Those bushings look crispy!! I would like ...   Sep 3, 2013 - 4:22 PM
- - presure2   QUOTE (Fate @ Sep 2, 2013 - 3:03 PM)...   Sep 3, 2013 - 4:22 PM
- - Ted95   Great work guys thing must handle like a dream now...   Sep 3, 2013 - 11:01 PM
|- - presure2   QUOTE (Ted95 @ Sep 4, 2013 - 12:01 A...   Sep 4, 2013 - 9:27 AM
- - richee3   It's confirmed, I do not have Sport suspension...   Sep 5, 2013 - 4:54 PM
- - enderswift   I've been meaning to ask. How is the squeaking...   Oct 1, 2013 - 11:01 PM
|- - presure2   QUOTE (enderswift @ Oct 2, 2013 - 12...   Oct 2, 2013 - 11:20 AM
- - cjh4l22   enjoy. did the same, only with d2's, and DAMN ...   Oct 1, 2013 - 11:04 PM
- - enderswift   awesome, the noise would really be a big issue for...   Oct 2, 2013 - 8:40 PM
- - qatar11   I really wish I could get those bushings in black....   Oct 3, 2013 - 4:06 PM
|- - gen6coupe   QUOTE (qatar11 @ Oct 3, 2013 - 4:06 ...   Oct 9, 2013 - 10:23 AM
- - b22ri22an   QUOTE (enderswift @ Oct 2, 2013 - 12...   Oct 9, 2013 - 4:26 AM
- - mgnt232   Hey had a quick qestion. Wth these coilovers is th...   Nov 2, 2013 - 2:03 AM
|- - presure2   QUOTE (mgnt232 @ Nov 2, 2013 - 3:03 ...   Nov 2, 2013 - 8:55 AM
|- - mgnt232   hey just saw your reply now. thanks, like i said i...   Nov 11, 2013 - 8:13 PM
- - njccmd2002   how in ends world, did you get the big bolt out of...   Jan 29, 2014 - 12:12 PM
- - Batman722   Heat up the hub and work the bolt out. Try putting...   Jan 29, 2014 - 3:56 PM
- - njccmd2002   I got a press today, the problem is that my propan...   Jan 29, 2014 - 5:47 PM
- - njccmd2002   with a map torch and convincing hammer, it came ou...   Jan 31, 2014 - 2:13 PM
- - Bitter   Really what you need is oxygen in there to, once t...   Feb 1, 2014 - 12:01 PM
- - presure2   yea, an oxy/acte. torch is the best way, but a map...   Feb 1, 2014 - 9:56 PM
- - Bitter   If the 6th gen responds anything like my 7th gen, ...   Feb 1, 2014 - 10:05 PM
- - slo_celly   Ordered my poly front and rears from Pawel yesterd...   Feb 20, 2014 - 2:29 AM
|- - njccmd2002   QUOTE (slo_celly @ Feb 20, 2014 - 1...   Feb 20, 2014 - 2:43 AM
- - slo_celly   Yeah, my car has been a consistent pia thus far. S...   Feb 20, 2014 - 1:32 PM
|- - mkernz22   QUOTE (slo_celly @ Feb 20, 2014 - 1...   Feb 20, 2014 - 1:57 PM
- - njccmd2002   in my case not all were bad, but the spindle bolts...   Feb 20, 2014 - 3:20 PM
- - slo_celly   Im prepared to battle these gremlins of car design...   Feb 20, 2014 - 3:39 PM
- - njccmd2002   this worked for me i drilled on of the sides to m...   Feb 20, 2014 - 7:59 PM
- - 1994Celica   How firm is the ride with the new bushings?   Feb 24, 2014 - 11:21 AM
- - presure2   definetly a bit firmer than stock, but totally in ...   Mar 2, 2014 - 12:08 PM
- - Bitter   It's much easier to find and hold the limit of...   Mar 2, 2014 - 4:32 PM
- - PizzaGuy01   Damn i sure hate to bring this thread back but for...   Jan 21, 2016 - 5:56 AM
|- - richee3   QUOTE (PizzaGuy01 @ Jan 21, 2016 - 4...   Jan 21, 2016 - 7:44 AM
- - njccmd2002   It does work. Been there. Done that and twice...   Jan 22, 2016 - 1:21 PM
- - presure2   QUOTE (richee3 @ Jan 21, 2016 - 7:44...   Jan 23, 2016 - 8:38 AM
Lo-Fi Version Time is now: September 1st, 2026 - 12:35 PM
