> Flickering Oil Light at Low Idle
post Sep 4, 2013 - 3:49 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
Hey guys, I have been noticing for the past while that my oil light will flicker when my car returns to idle when I am driving (1996 Celica 2.2L 5SFE). I have been doing some research on the cause and it sounds like it could be related to a stuck oil pressure release valve on the oil pump.
Anyone have any experience servicing one of these? I have read that you can service it with the pump off the most easily, but it requires taking the timing belt off of course which I would prefer to not do. It sounds like you might be able to service it from below by taking off the oil pan. I don't know if my pan has ever been taken off or the screen cleaned. That might be something else to check.
Any thoughts or experiences? I would hate for some greater damage to happen to my car.
for the record, oil level is great, oil filter is new (Toyota OEM) about 900 kms ago, issue happened with old filter as well. The issue also seems to hapen after the car is warmed up. I had my timing belt, water pump and seals replaced about 1500 kms ago. Could it be related?
Help!
This post has been edited by Sinyk: Sep 4, 2013 - 3:51 PM
- Sinyk   Flickering Oil Light at Low Idle   Sep 4, 2013 - 3:49 PM
- - Box   Could be the sensor perhaps, if you're lucky. ...   Sep 4, 2013 - 6:45 PM
- - Pfloyd09   When that started happening to mine it was the oil...   Sep 4, 2013 - 11:50 PM
- - Sinyk   I have had the sensor replaced a couple times afte...   Sep 5, 2013 - 10:32 AM
|- - Pfloyd09   I had just moved cross country without my tools so...   Sep 5, 2013 - 11:06 AM
- - Sinyk   hmmm, i wonder if a local shop would do the replac...   Sep 5, 2013 - 11:14 AM
|- - Pfloyd09   You hafta drop the exhaust manifold, and there is ...   Sep 5, 2013 - 2:15 PM
- - Sinyk   I have a usual mechanic, I'll see what kind of...   Sep 5, 2013 - 2:18 PM
- - RabidTRD   What weight of oil are you using and what is your ...   Sep 5, 2013 - 3:17 PM
- - Sinyk   10W30. right now it's about 22C outside, rough...   Sep 5, 2013 - 3:37 PM
- - Sinyk   I was told it is a 6 1/2 hour job (i can't rec...   Sep 5, 2013 - 4:43 PM
- - Box   Kind of sucks to have to spring over $700 for...   Sep 5, 2013 - 5:30 PM
- - Sinyk   The symptoms of this issue actually crop up after ...   Sep 5, 2013 - 5:49 PM
- - Box   Being that letting it idle up to temp keeps it fro...   Sep 5, 2013 - 6:17 PM
- - Bitter   Get a mechanical oil pressure gauge and verify wha...   Sep 5, 2013 - 7:07 PM
- - Sinyk   Box: Currently I am babying it. I'm driving li...   Sep 6, 2013 - 12:47 PM
|- - Bitter   QUOTE (Sinyk @ Sep 6, 2013 - 12:47 P...   Sep 6, 2013 - 8:04 PM
- - Special_Edy   As the oil warms it thins. Something that hasnt b...   Sep 6, 2013 - 3:06 PM
- - Box   Being he admitted to not being able to do the oil ...   Sep 6, 2013 - 3:31 PM
- - Sinyk   will 20w-50 have any ill effects? That's prett...   Sep 6, 2013 - 3:34 PM
- - Box   I was just saying use it temporarily to see if tha...   Sep 6, 2013 - 4:37 PM
- - Box   ^That. Then you'll know for sure what's g...   Sep 6, 2013 - 9:16 PM
- - Sinyk   They (mechanic) checked the pressure and said it w...   Sep 10, 2013 - 6:03 PM
- - Galcobar   That's why they sent out an e-mail about buyin...   Sep 11, 2013 - 2:35 AM
- - Sinyk   ah crap. i recall that email but i hadn't orde...   Sep 12, 2013 - 10:52 AM
- - 6strngs   Oil pump replacement is basically all of the work ...   Sep 15, 2013 - 12:01 AM
- - Sinyk   Perhaps, but I don't have the time (2 month ol...   Sep 16, 2013 - 11:38 AM
Lo-Fi Version Time is now: September 11th, 2026 - 6:42 PM
