> Probably simple, but hood latch assembly help
post Sep 8, 2013 - 3:49 PM
gts4
Joined Dec 20, '11
From gta
Just took apart my hood latch. Hood closes and locks intermittently. I took apart the whole assembly. 3 10mm bolts, 2 springs, and some metal. I left the latch wire running through the car. It looks bent or stretched where the tension and spring sits.
How can I clean and lubricate this best myself? There's a lot of wet dirt built up. Not sure what to use. Also, what kind of grease should I put on afterward, if at all?
Thanks.
post Sep 8, 2013 - 10:23 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
thats all you can do, clean it and lube it up.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: September 3rd, 2026 - 2:25 AM
