Sep 9, 2013 - 3:24 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '05 From Indianapolis Currently Offline Reputation: 0 (0%) |
Just finished a nice long two hour ride through the country. Top was down, speeds were up. Things were great. Then I stopped and tried to put the top up. The motor runs and it gets about a 10th of the way up but then seems to get stuck. When I had someone try and help it up while I push the switch it stayed just as stuck. Is this a motor problem or does something need to be lubed? Also, how do I raise this thing manually?
Terzin1 top wont go up. greattttttttt. Sep 9, 2013 - 3:24 PM
FrankB2 There is an access door in the trunk for the manua... Sep 9, 2013 - 8:01 PM
njccmd2002 if you can close after you flip this switch manual... Sep 9, 2013 - 9:08 PM
Terzin1 I knew about that switch and Tried using it to no ... Sep 10, 2013 - 8:00 AM
Terzin1 so under further investigation, it appears that wh... Sep 10, 2013 - 9:06 AM
njccmd2002 no maybe the motor is bad, but both motors should ... Sep 12, 2013 - 8:41 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 9th, 2026 - 12:59 PM |
