Sep 11, 2013 - 6:39 AM
Enthusiast ![]() ![]() Joined Mar 10, '11 From New Jersey Currently Offline Reputation: 1 (100%) |
so last night my cousin decided to change all my wires and use bigger gauges to my amp
and also put a stronger amp. (which he couldnt finish because it got too late) but anyways this morning as im driving to work, im listening to the radio and out of no where, Zap ZAAp zap ZAp from behind the radio, and OFF goes everything. I pull over and removed my radio, noticed he forgot to wrap around the remote wire with black tap.so it must have touched some metal from the car and made it trigger off. so i open my hood, disconnect my battery, black tape the remote wire, put the radio back in and i get no power stil from the radio, amp is also off.. im guessing i blew the fuse to the radio if there is any ? -------------------- 94' Celica GT Manual |
Sep 11, 2013 - 7:03 AM
![]() Enthusiast ![]() ![]() Joined Jul 17, '12 From Slovenia Currently Offline Reputation: 0 (0%) |
Definitely... Check the radio fuse, if i'm not mistaken, it is located in that plastic case under the hood alongside the fender
Sep 11, 2013 - 7:28 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
sometimes the radio itself has a fuse on the back of the unit so check that as well
-------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Sep 11, 2013 - 7:40 AM
Definitely... Check the radio fuse, if i'm not mistaken, it is located in that plastic case under the hood alongside the fender are u talking about these fuses ? i checked all the fuse with the light up checker gadget, all seem to work.. i wonder if the fuse is inside ? ![]() sometimes the radio itself has a fuse on the back of the unit so check that as well unfortanately, this isnt the greatest aftermarket radio, no fuse in the back .. the radio 20A fuse was OK.. forgot to mention. -------------------- 94' Celica GT Manual |
Sep 11, 2013 - 8:04 AM
Enthusiast ![]() Joined Oct 25, '12 From Pennsylvania Currently Offline Reputation: 0 (0%) |
Your cousin might not have tapped something else for power, or the radio/amp might have fried. If you have a multimeter, you can check the wire going into the radio for power. If you have power, it's the radio or amp.
Sep 11, 2013 - 8:11 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '13 From Winnipeg, MB, Canada Currently Offline Reputation: 14 (100%) |
There's a fuse box to the left under the steering wheel. The fuse is in there, if I remember correctly it's a 7.5A, check that one
-------------------- 2007 Impreza 2.5i - Daily
1994 Camry - Sold 1994 Celica - Sold :( ![]() Click here to see my progress thread! |
Sep 11, 2013 - 8:37 AM
There's a fuse box to the left under the steering wheel. The fuse is in there, if I remember correctly it's a 7.5A, check that one Thanks the fuse i needed was definitely in there, although it wasnt any of the 7.5 it was the fuse on the bottom row marked 15, it was burnt pretty bad. picture after replacement: ![]() *Replaced and i have Music again ! Thanks A Lot Everyone ! -------------------- 94' Celica GT Manual |
Sep 11, 2013 - 8:53 AM
Ohh yeah I knew it was either 7.5 or 15 haha. Glad you got it working!
| Lo-Fi Version | Time is now: September 13th, 2026 - 1:30 AM |
