Sep 14, 2013 - 1:18 PM
Enthusiast ![]() Joined Dec 29, '08 From midwest Currently Offline Reputation: 0 (0%) |
Is there a way to disconnect all the bulbs further back in the wiring so I can pop them all into the tail light itself away from the car, and then reconnect the wire? Maybe a dumb question, but it's kind of tricky trying to hold the actual tail light unit while trying to twist all the bulbs in. I did not see an area where all the wire came into one lead for me to disconnect, but thought I would see if anyone knew. Thanks
This post has been edited by 6thcelestial: Sep 14, 2013 - 1:19 PM |
Sep 14, 2013 - 1:23 PM
Enthusiast ![]() Joined Jan 27, '08 From Mass Currently Offline Reputation: 6 (100%) |
Is there a way to disconnect all the bulbs further back in the wiring so I can pop them all into the tail light itself away from the car, and then reconnect the wire? Maybe a dumb question, but it's kind of tricky trying to hold the actual tail light unit while trying to twist all the bulbs in. I did not see an area where all the wire came into one lead for me to disconnect, but thought I would see if anyone knew. Thanks Yeah, the main plug for each light is in the trunk. It's about 6 inches from where it goes into the car. It's is pretty easy to get to. You just need to remove some of the trunk plastics. |
Sep 14, 2013 - 2:24 PM
Thanks, that is a big help. Is it just a single snap connection at one point?
Sep 14, 2013 - 2:35 PM
Yeah it's just one plug per side.
Sep 14, 2013 - 3:17 PM
Yeah it's just one plug per side. Thanks Rivs. I am not at the car right now where I've got it taken apart, but is the connection right behind both side panels, and do you remember what color they are? Once disconnected, I can take the whole tail light unit out , bulbs and all, right? |
Sep 14, 2013 - 3:49 PM
Yeah you'll be able to pull the whole light out. Just the rubber grommets on the wire will be left. I believe the connector was white.
Sep 16, 2013 - 9:16 AM
Thanks Rivs. Hopefully getting out to the car today to finish up. I remember the opening for the wires to be pretty small. How do you get the wires/connector out through it?
Sep 16, 2013 - 9:20 AM
Thanks Rivs. Hopefully getting out to the car today to finish up. I remember the opening for the wires to be pretty small. How do you get the wires/connector out through it? Once you remove the rubber grommet, the hole is big enough for the wire and connector. |
Sep 16, 2013 - 10:54 AM
Thanks Rivs. I am guessing that the grommet goes back in pretty easily, and stays put afterwards.
| Lo-Fi Version | Time is now: September 12th, 2026 - 3:07 AM |
