Sep 16, 2013 - 3:53 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 11, '08 From London Currently Offline Reputation: 7 (100%) |
That they only come on when the engine is on. Not in ignition because I dont want any power drain on start up.
Sep 16, 2013 - 4:27 PM
Could always wire them to trigger on with the side-marker lights.
Sep 16, 2013 - 4:42 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 12, '13 Currently Offline Reputation: 53 (100%) |
To the ACC then.
Sep 16, 2013 - 4:59 PM
Or better, delay circuit wired to ignition.
Sep 17, 2013 - 4:17 AM
Could always wire them to trigger on with the side-marker lights. I would rather they just come on when the engine is on. To the ACC then. Or better, delay circuit wired to ignition. ACC? Delay circuit sounds good but delay from what? In ignition? Would rather keep it simple and attach it to a source which turns on when the alternator is on such as power steering or something. |
Sep 17, 2013 - 4:35 AM
Just go with the cigarette lighter as a trigger if you want them on all the time when the car is on.
Sep 17, 2013 - 5:25 AM
ACC also know as auxiliary.
![]() With a circuit it will work this way. Turn key to ignition and start engine, circuit receives signal and countdown begins, DRL start after a set time, maybe 10 seconds. I don't see what the big deal is with them being on while cranking. I've got a big audio system and crank it all the time with it on. A DRL won't be that hard on it. And it will be easy to wire. |
Sep 17, 2013 - 11:05 AM
I have the tiniest battery ever and it provides just enough amps to crank it over and power the clock at the same time
ACC was what I was avoiding. I was told to use alt wire to switch relay? |
Sep 17, 2013 - 11:43 AM
When the key is turned to "ON", the entire vehicle receives power.
When the key is turned to "START", only the starter, ecu and distributor recieve power. Thus, nothing should be draining your battery while you are starting the car. But the timer idea sounds like a feasible option. You could build one using a 555 timer, a couple counter ICs and a transistor. |
Sep 17, 2013 - 11:48 AM
Enthusiast ![]() ![]() ![]() Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) |
Radio loses power during crank...I think. Wire it to that.
I don't see the issue though, DLRs are like what 16watts? That's like 2.6amps for both tops. Edit: Special Eddy- All the lights stay on. At least in the '95 they did. My radio is the only thing that shuts off that I know of. But then again its not like I sit there and hold in on start for a minute so I'm not really sure This post has been edited by travisxcore: Sep 17, 2013 - 11:50 AM |
Sep 17, 2013 - 11:56 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
One of the wires (can't remember which pin) in the diagnostic port only goes live when the engine is running.
Then you can make your own relay (or just buy a universal DRL kit) and tap into this wire to trigger it to supply power from the battery to the lights. I bought this kit (Source) and installed it to my GT-Four when I imported it. This post has been edited by azian_advanced: Sep 17, 2013 - 11:57 AM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Sep 17, 2013 - 2:04 PM
If he's using LED DLR's the power draw will be menial though. Hell, even halogen DLR's wouldn't be that bad. Though if you could find the wire that azian spoke of that'd be ideal. Use that to power a relay to turn the DLR's on and off.
Sep 17, 2013 - 2:51 PM
Sounds like a good plan Azian.
If I have any of my lights, radio, dash light on or use the window, heater or anything. My car will not start. This post has been edited by yellowchinaman: Sep 17, 2013 - 2:53 PM |
Sep 17, 2013 - 3:27 PM
Time for a new battery.
Sep 17, 2013 - 5:29 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
You must have a tiny battery lol
This post has been edited by SupraKid: Sep 17, 2013 - 5:30 PM |
Sep 18, 2013 - 6:21 AM
Caterham Banner battery. Its only needed to turn the engine over.
This post has been edited by yellowchinaman: Sep 18, 2013 - 6:21 AM |
Sep 22, 2013 - 7:10 PM
Enthusiast ![]() ![]() ![]() Joined Jul 5, '09 From Katy/houston Currently Offline Reputation: 16 (100%) |
What about getting the power from one of the fans or cruise control, just an idea don't really know for sure, but they should only get power when engines running no?
-------------------- For Sale:OEM tail lights - make offer
Sep 22, 2013 - 7:54 PM
They're not constant though, especially the fans. Finding the wire that azian mentioned to tap into will be ideal.
| Lo-Fi Version | Time is now: August 28th, 2026 - 4:54 AM |
