Jan 27, 2004 - 11:16 PM
ok my car consumes oil rather fast...any ideas why?
Jan 27, 2004 - 11:25 PM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 30, '02 From Franklin,Tn Currently Offline Reputation: 0 (0%) |
It depends on how many mile are on it, how hard you drive it, you could have a leak. There are a few things that can cause you to consume oil. Give us some info on how you drive it.
Bryan |
Jan 28, 2004 - 2:22 AM
ok, hey mine is the same, well not too fast, but i have a 94 st with i think now its 133k on it, an i dont drive real fast or rag it, but i norm shift between 3-4 on most days, an when im just chillen around 2-3, im not to hard on it, but i noticed that i burn or leak oil, im not postive but i think its somewhere between a quart every 800-1k mile. is there a comon place that these engines leak??
Jan 28, 2004 - 12:46 PM
Enthusiast ![]() Joined Mar 18, '03 From Quebec Currently Offline Reputation: 0 (0%) |
..many Toyota Car from 1993 to 1998 take oil.
My ST have taken 1liter/850Km... I rebuilt the motor... The ring of the piston was glue... I think you should rebuild the motor OR try to change the ECR Valve( I not sure this the good name....but it's place on the top of the motor..)It's a little valve that should cost you 10-15$US to change |
Jan 28, 2004 - 2:30 PM
Enthusiast ![]() ![]() ![]() Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
do you mean the PCV valve? once oil is leaking throught there it is usually piston/ring related. a rebuild will be in the near future. |
Jan 29, 2004 - 12:28 AM
Yes! PCV Valve!
Jan 30, 2004 - 2:57 PM
Enthusiast ![]() ![]() ![]() Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
There's only 5 ways it can use oil, 1 - past worn rings 2 - past the valve seals 3 - leaks (gaskets or seals or damaged oil pan etc) 4 - sucked thru bad PCV (positive crankcase ventilation) valve 5 - bad cylinder head gasket leaking oil into coolant or cylinder. these are not in any particular order, I would start with the PCV and checking for leaks (may be other odd/rare ways, like cracked head or block, but we don't want to thinkl about those) |
| Lo-Fi Version | Time is now: August 26th, 2026 - 7:05 AM |
