> Strut mount top bolt recommended torque?, New struts, one side is noisy, other side is fine
post Oct 6, 2013 - 7:26 PM
gen6coupe
Joined Sep 13, '10
From Austin, tx
Hi, I just replaced my entire strut assembly on the rear of my 95 ST coupe (strut, lower insulator, bellow/bumper, lowering springs, top mount). Also did sway bar bushing and Moog endlinks. Everything went fine (24" snap-on breaker bar was worth every penny!), minus my rookie mistake of not checking which strut I was using on which side! DOH. It made the other side that much faster cuz i already had the sucker put together and ready to go. wink.gif
ANYWAY. The new struts have made all the difference, the car was not able to be driven before, the ass end bounced all over the place. But Im noticing on the right side I get some noise, almost like metal clanging? when it hits hard. Left side is solid and quiet. What should I check?
The only difference I noticed was my right side top bolt had more threading than the other side. Could this be the cause? Obviously this means I torqued one side more than the other.. could it be the spring being compressed harder and bouncing back harder? I noticed the stock ones the nut was barely on there. This matches more like my left (quiet) side where I have about a half inch of threading through the bolt.
Does anyone know the correct amount of torque to put on this bolt (i have a coupe). Also is it ok to make this adjustment while everything is mounted up? I left the backseat and trunk stripped so its easy to get back in there if needed. Taking it all out would be a pain in the ass though. Right now Im glad its not my DD but I want it to be!
any help is appreciated!
This post has been edited by gen6coupe: Oct 7, 2013 - 2:18 AM
Lo-Fi Version Time is now: September 12th, 2026 - 3:09 AM
