> Using more petrol? Unknown reason :(
post Oct 8, 2013 - 4:21 AM
Liam_c
Joined Nov 29, '12
From New Zealand
Lately my car has been using more petrol than what it usually would, and i have no idea why.
When i bought the car, i was running it on 91 octane, and it was using about 8.5 L per 100km, and then about 2 months ago i upgraded to 95 octane and it was using 8.1L per 100km. No mater how i drove it on 95, it was doing high kms every tank i was loving it biggrin.gif
But recently, its jumped back up to 8.5L per 100kms, and even though im driving it nicely, its still using alot of petrol. I started to notice it shortly after i had taken it on a car club run about a month ago ( driving around the hills, giving it a bit of stonk in the hills)
To some of you, this may not really be a problem, but its worrying me as i don't want it to get worse (and on my current run, it seems to be getting worse frown.gif )
Where would be a good place to start looking for what could be causing this issue? I'm 90% sure it isn't a leak, as there is no noticeable marks on the ground after being parked up.
Air filter? Catalytic converter? Wrong fuel type? Fuel filter? O2 sensor?
Engines a 3sfe.
Replies (1 - 10)
post Oct 8, 2013 - 6:13 AM
Box
Joined Feb 23, '12
From Warrior, AL
Spark plugs and wires if they haven't been replaced in awhile. People like to never change the fuel filter, so I'd check that too. Another thing is change in temperature can affect mileage, for most parts of the world temperatures are starting to shift one way or another this time of year.
2001 Miata LS 5-speed
post Oct 8, 2013 - 6:55 AM
rentaspace
Joined Sep 23, '12
From Australia
Follow the guide on here for resetting the ECU, when I first got my car I was using 12-15L/100km, after I followed the reset guide it dropped to 11.3L/100km.
Then as box said, change fuel filter, ignition leads and spark plugs. While I was at it, I also changed my oil, oil filter and radiator fluid.
I am now using 9-9.5L/100km after these changes smile.gif
EDIT:
I also use 95, but sometimes (probably once quarterly) I will use e10 to clean the inside of the tank out tongue.gif
When I do the e10 run I ise 12L/100km... Terrible...
The one time I used 98, I got 8.4L/100km
This post has been edited by rentaspace: Oct 8, 2013 - 6:57 AM
post Oct 8, 2013 - 2:58 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Oct 8, 2013 - 11:18 PM
bnr32celica
Joined Jan 16, '12
From 860, ct
tuneup time! For us americans, you're doing roughly 26mpg, which isn't great.
Also, have you checked physical timing (off the distributor) recently?
post Oct 9, 2013 - 6:10 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
Your upstream O2 sensor is what controls fuel trim. If it hasn't been replaced, look at that at the same time as the tune-up.
post Oct 9, 2013 - 7:06 AM
rentaspace
Joined Sep 23, '12
From Australia
QUOTE (Box @ Oct 8, 2013 - 3:58 PM) *
usually you disconnect the battery white doing the tune up (especially when playing with fuel systems), and this should reset the ECU too tongue.gif
post Oct 9, 2013 - 7:43 AM
Box
Joined Feb 23, '12
From Warrior, AL
Disconnecting the battery will reset the ECU anyhow, but it resets everything else. I'm too lazy to reset my radio so unless it's detrimental there be no power I leave the battery in place. tongue.gif
post Oct 9, 2013 - 4:59 PM
rentaspace
Joined Sep 23, '12
From Australia
QUOTE (Box @ Oct 9, 2013 - 7:43 AM) *
I'm not too fussed on radio, as I use my phone for in-car music anyhow... Adjusting all the sound settings though, that pisses me off because every time I reset it I can never get it back to where it was... kindasad.gif Even with the same settings it sounds different for some reason >.<
post Oct 9, 2013 - 6:15 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Oct 11, 2013 - 5:55 PM
Liam_c
Joined Nov 29, '12
From New Zealand
Thanks for the input guys!
I reset my ecu last night and then filled up with bp's 95 (shhh, i work for an opposition tongue.gif ) so ill see how this run goes.
My cars getting a WOF at work next week, so i might ask how much it will cost to get spark plugs done, filter, etc.
I've recently done an oil change, so it may or may not be having an effect... Im using magnatec 10w-40. Was like 60 bucks for 4L D:
Lo-Fi Version Time is now: August 9th, 2026 - 4:33 PM
