> 95 head on 96 7afe.
post Oct 29, 2013 - 7:38 PM
beefstrudel
Joined Sep 26, '10
From Kentucky
I'm replacing the head on my 96 celi. Fried some valves with nitrous... Lol.. Learned my lesson tho. Anyway. I've noticed this new head I picked up doesn't have a water outlet for the intake manifold. And mine does.. Can I just drill a hole? It looks like it would be fine. But I want expert opinion. And does the intake really need coolant going through it? Thanks in advance. Need am answer asap so I can get back on the road. 7afe btw
This post has been edited by beefstrudel: Oct 29, 2013 - 8:05 PM
post Oct 29, 2013 - 8:43 PM
mgnt232
Joined Mar 16, '09
why on earth would you run nitrous through an economy 7afe? was the power goal a whole 120hp?
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Oct 29, 2013 - 10:10 PM
Syaoran
Joined Jan 4, '12
From US
How can something as cold as nitrous fry valves? lol
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Oct 29, 2013 - 11:10 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
You sure you don't mean EGR passage?
post Oct 30, 2013 - 12:20 AM
beefstrudel
Joined Sep 26, '10
From Kentucky
It made quite an amazing amount of torque. 65 wet shot. Cylinder 1 got lean because its farthest from the intake. Melted the aluminum in combustion chamber so valves can't seat. . This hole I'm talking about is on the right side of the intake side of the head. If you're looking at the engine from the front of the car. Is it egr? Can post pictures tomorrow. My first guess was a water passage. So any way to make this head work or do I need to go back to the junkyard
Edit: yeah I'm about 90% sure its egr now... I guess this is a question if it'll work or not. Egr delete? I don't care about cel. Will it affect driveability?
This post has been edited by beefstrudel: Oct 30, 2013 - 12:43 AM
post Oct 30, 2013 - 10:10 AM
Syaoran
Joined Jan 4, '12
From US
You won't feel any changes from eliminating the EGR. I eliminated mine and the car runs just fine without it.
post Oct 30, 2013 - 10:29 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
i would check the pistons. if you did that much damage in the head, the lower section might be hurt too.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Oct 30, 2013 - 1:39 PM
beefstrudel
Joined Sep 26, '10
From Kentucky
Bottom end is fine. It still ran just on 3 cylinders. Have to drive about 80 miles home like that. Are the 7a's pistons iron or aluminum? Really hoping they're iron
post Oct 30, 2013 - 3:46 PM
beefstrudel
Joined Sep 26, '10
From Kentucky
Head gasket arrived. Coolant passages don't line up with new head.. no I'm.guessing they won't with the block either.. awesome.
post Oct 30, 2013 - 4:09 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
they are cast, slag metal.
are you sure its the right head gasket?
post Oct 30, 2013 - 4:36 PM
beefstrudel
Joined Sep 26, '10
From Kentucky
Pretty sure. Should the coolant passages be the same on 95 and 96? This is all the junkyards fault too because they marked the car I got the head from as a 96. Turns out its a 95! Grr. I just really hope I can make this one work because I've already cleaned it up really well.
post Oct 30, 2013 - 7:53 PM
Bitter
Joined Mar 11, '06
You sure you even got a head from an A engine?
post Oct 30, 2013 - 9:51 PM
beefstrudel
Joined Sep 26, '10
From Kentucky
Definitely a 7a head. Just non egr. Do the water jackets line up on all A engines? I haven't pulled my head all the way yet. Dont wanna chance anything rusting. Not gonna take it all the way off till I'm 100% sure I have the right one. I'm just going to the yard in morning and pulling one off a 96 with egr. Mines a 96 so everything should be dandy then. Ita def an A head. Narrow valve angle slave cam setup.
post Oct 30, 2013 - 11:04 PM
Bitter
Joined Mar 11, '06
The S head on the 5SFE is also slave cam and narrow angle. Cam gears should be all the way at the end of the head, not toward the middle.
post Oct 31, 2013 - 7:10 AM
beefstrudel
Joined Sep 26, '10
From Kentucky
Its off a 7a for sure. I know the 5s is mounted at a different angle. I can tell the engines apart pretty easily. I'm going to the junkyard in about an hour to pull a head off a 96 so I'll have egr and no worry about head lining up. Good thing i bought the 4 dollar warranty lol.
post Nov 2, 2013 - 8:26 AM
blackliftback
Joined Mar 1, '12
From iowa
I was going to say... Couldnt you just use your 96 intake manifold on the 95 head in order to have the egr?
post Nov 3, 2013 - 6:27 PM
beefstrudel
Joined Sep 26, '10
From Kentucky
There's a hole in the head that goes into the Mani for egr. I have it running now... But now my problem is on the interstate it randomly blows thick clouds of oil smoke. Valve stem seals?
Lo-Fi Version Time is now: September 12th, 2026 - 2:23 AM
