> how much offset?, 35mm or 45mm
post Jan 28, 2004 - 9:52 PM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
I am about to buy rims and i was wondering what offset i should go with. the wheels i was looking at are 18X7.5 and i wanted to know what offset would keep the wheel from sticking out the rest of my car? the tires are gonna be 215/35R18
thanks
-Stew
post Jan 28, 2004 - 11:27 PM
dcgoalie312
Joined Dec 20, '02
From OKC
i would say go with 35mm cuz i believe 38mm is stock (someone please verify that number)
DREW
post Jan 29, 2004 - 12:11 AM
aaronc222
Joined Sep 22, '02
From Detroit
38 is stock. The lower the number the more the rims will stick out from the wheel well.
post Jan 29, 2004 - 1:00 AM
SpedToe169
From Dallas, Tx
But remember that stock the wheels are waaaay in the fenders. I'm running 6.5" wide wheels with a 38mm offset and 25mm spacers. So the offset is effectively 13mm. If those are your only two options, I would go with the 35mm. They're not even going to be close to sticking out even tho they're 7.5" wide.
post Jan 29, 2004 - 11:30 AM
Cormudgen
Joined Jul 31, '03
From GA
i have 18x7.5 with a 35 offset. they dont stick out, line up perfectly: but you will have a problem with rubbing if you get a larger size tire and are lowred. the tire size you intend to go with is fine. I'm about to drop down to that size myself actually.
cormudgen
post Jan 29, 2004 - 12:54 PM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
hey cormudgen where in GA you live?
post Feb 2, 2004 - 5:30 PM
Joined Jan 27, '03
From st.lucia
use 43 - 45 offset that should do just fine.
post Feb 3, 2004 - 1:57 AM
SpedToe169
From Dallas, Tx
Did you read any of the rest of the thread????
Don't get 43-45s.
post Feb 3, 2004 - 7:34 AM
Cormudgen
Joined Jul 31, '03
From GA
QUOTE (BEEFSTEW800 @ Jan 29, 2004 - 10:54 AM)
from Dublin, hour from macon on I-16 but go to school @ GA Southern
hour from Savanah on I-16
post Feb 3, 2004 - 12:15 PM
so, offset is the thickness of the rim at the poin where the lugs get put on?
my current rims are 40 offset and im trying to see what kind of spacers i could get for them. if i get 5mm spacers then my offset would change to 35mm, right? is that the maximum offset i can have, and still have enough of the bolt left to make sure the nuts are on safely? i know i can get larger spacers that come with their own bolts, but i feel a little uneasy about something that i have bolt on to my car, and then the wheel bolts on to that.
Lo-Fi Version Time is now: August 29th, 2026 - 6:32 PM
