> ct26-gt30 what should I expect?
post Nov 11, 2013 - 6:16 PM
underground_desi...
Joined Dec 4, '11
From Greece
I have recently found a ct26 turbo for sale. It is fully rebuild with garret gt30 internals.
The seller claims the turbo is up to 480 hp.
Could that be true?
This is it
Replies (1 - 6)
post Nov 13, 2013 - 11:20 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
I call BS! I dont see any machine work on the inlet of the turbo. a GT30 is a much larger compressor wheel over the CT26.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 13, 2013 - 1:12 PM
underground_desi...
Joined Dec 4, '11
From Greece
QUOTE (Smaay @ Nov 13, 2013 - 11:20 AM) *
I will get some more photos if that helps.
If there is a possibility that the turbo is a hybrid ct26 gt30 , how much power could it handle?
post Nov 13, 2013 - 3:03 PM
95celgt
Joined Oct 5, '03
From South TX.
that's a regular ct26 be careful
post Nov 13, 2013 - 3:39 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (underground_design @ Nov 11, 2013 - 7:16 PM) *
Could that be true?
This is it
I didn't know garrett made internals for Toyota turbos....
Rebuilt with x or y internals doesn't mean anything in terms of power productions. The wheels have to be changed. And a GT30 wheel on a CT26 would make for an inefficient turbo.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Nov 13, 2013 - 5:25 PM
The problem with those hybrid setups is none of them (other than the ats racing "ct-27") addresses the boggest restriction, the exhaust housing itself.
Putting in anything larger than a 46 trim wheel just creates more lag without gaining much more up top.
Then once guys realize that, they start "clipping" the exhaust wheel, which in turn just creates more lag, again without adding much overall flow up top.
Ats racing went thru a whole bunch of diffrent tests with diffrent compressor wheels, and eventually settled in on the 46 and 50 trim compressor wheels, with some machining of the exhaust housing, and even eventually stopped selling the 50trim version.
What they ended up with is a turbo that basically performs like a ct-20b, with just a hair more top end and maybe 1-200rpm diffrence in spool vs a stock turbo.
Trying to cram a big compressor wheel in there with a stock exhaust side just creates a really badly matched turbo, that just performs like as$.
If you wanna upgrade for the stock ct26, pick up a ct20b. The market is good for em right now, you can get em for around 400 if your patient, and they are a nice upgrade over stock.
post Nov 13, 2013 - 5:34 PM
underground_desi...
Joined Dec 4, '11
From Greece
You got me covered!
I'm going just to ignore it and search for a proper turbo.
Thank you !!
Lo-Fi Version Time is now: August 23rd, 2026 - 7:18 AM
