Nov 17, 2013 - 4:36 PM
Enthusiast ![]() Joined Dec 9, '05 From Germany Currently Offline Reputation: 0 (0%) |
It´s not the most usefull thing but i just felt the urge to build something like this
This is the outcome: Arduino Micro Shift Light Test setup ![]() I used my mini DSO as signal generator, a wonderful little tool. ![]() ![]() ![]()
Nov 17, 2013 - 7:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '13 From Winnipeg, MB, Canada Currently Offline Reputation: 14 (100%) |
Really cool! Good job
-------------------- 2007 Impreza 2.5i - Daily
1994 Camry - Sold 1994 Celica - Sold :( ![]() Click here to see my progress thread! |
Nov 18, 2013 - 11:48 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
awesome
-------------------- Mike W
Nov 19, 2013 - 11:54 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 12, '13 From Cleveland Currently Offline Reputation: 5 (100%) |
Thats prettty sweet, nice work
Nov 20, 2013 - 10:25 AM
Enthusiast ![]() ![]() ![]() Joined Jul 5, '09 From Katy/houston Currently Offline Reputation: 16 (100%) |
Would you awesome and show us how you made this work?
-------------------- For Sale:OEM tail lights - make offer
Nov 20, 2013 - 1:38 PM
This is basically how i made it, would have been a lot easier with normal LEDs but i wanted them all to be able to blink blue so i had to use RGB LEDs.
I put 1000-2000 Ohm resistors in front of every used LED pin, they were still way to bright but thanks to the PWM outputs its easy to dim them and to make any color as i did with the yellow stage. ![]() And this is the code for the Arduino, not perfect, i still need to get some kind of rpm or frequency counter working, for now the code counts the time between the pulses: QUOTE int rev = 12;
int ledGr1 = 5; int ledGr2 = 13; int ledGr3 = 11; int ledG1 = 6; int ledG2 = 9; int ledRo = 3; int ledBl = 10; int ledAll = 8; unsigned long duration; void setup(){ Serial.begin(19200); pinMode(8, OUTPUT); pinMode(rev, INPUT); } void loop(){ Serial.print("Duration: "); Serial.println(duration); duration = pulseIn(rev, HIGH); if (duration < 800 && duration > 100) { digitalWrite(ledAll, HIGH); delay(40); digitalWrite(ledAll, LOW); delay(40); } if (duration < 2800) analogWrite(ledGr1, 20); if (duration > 2850 || duration < 800) analogWrite(ledGr1, 0); if (duration < 2500) analogWrite(ledGr2, 20); if (duration > 2550 || duration < 800) analogWrite(ledGr2, 0); if (duration < 2300) analogWrite(ledGr3, 20); if (duration > 2350 || duration < 800) analogWrite(ledGr3, 0); if (duration < 2000) analogWrite(ledG1, 20); if (duration > 2050 || duration < 800) analogWrite(ledG1, 0); if (duration < 2000) analogWrite(ledG2, 60); if (duration > 2050 || duration < 800) analogWrite(ledG2, 0); if (duration < 1500) analogWrite(ledRo, 40); if (duration > 1550 || duration < 800) analogWrite(ledRo, 0); if (duration < 1100) analogWrite(ledBl, 20); if (duration > 1150 || duration < 800) analogWrite(ledBl, 0); delay(50); } |
Nov 29, 2013 - 11:02 AM
Enthusiast Joined Oct 18, '09 From España Currently Offline Reputation: 0 (0%) |
It is really impressive, good work. I have a question, where to get the rpm signal?
Nov 29, 2013 - 11:32 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
Looks like I'm going to have to make one some day!
What was the overall cost of this? Edit: Never mind, just looked it up at Radioshack and it's only $30 for the board! The only thing is, I would have to program it to use all the individual LED's and not have it jump to doubles, after the green, like you currently have it. I wouldn't have the blues in there either. Probably just have 3 green, 2 yellows, 2 red, and no extra ones for blue, but have all them flash blue when it's at the set shift point. This post has been edited by mkernz22: Nov 29, 2013 - 11:49 AM |
Nov 29, 2013 - 2:38 PM
It is really impressive, good work. I have a question, where to get the rpm signal? I took the rpm signal from my EMS Motorsport ECU but you can take any signal that changes with rpm, ignition or injector signals should work. With the stock ignition system you can simply take the signal wire that feeds the tach. The only thing is, I would have to program it to use all the individual LED's and not have it jump to doubles, after the green, like you currently have it. I wouldn't have the blues in there either. Probably just have 3 green, 2 yellows, 2 red, and no extra ones for blue, but have all them flash blue when it's at the set shift point. Should be no problem as long as you have enough output pins |
Feb 16, 2014 - 12:10 PM
Enthusiast Joined Feb 15, '14 From UK Currently Offline Reputation: 0 (0%) |
Hi,
Just wondering what spec diodes you used between the Arduino on Pin 8 and 10 (PWM) and the LEDs. Thinking of having a go at this myself but was wondering roughly what diodes I'll need to protect the board? Thanks, Sean |
| Lo-Fi Version | Time is now: July 30th, 2026 - 4:48 AM |
