Nov 25, 2013 - 2:52 PM
Enthusiast Joined Nov 25, '13 From tulsa ok Currently Offline Reputation: 0 (0%) |
Hello, i'm just going to start off as im a complete noob but i will try my best to describe the problem i'm having, yesterday i bought a 96 gt celica convertible (for cheep) and i found out it has a running 3sgte in it. the problem i'm having is that it idles extremely rough. and will die unless i rev it up abit but while driving and my foot on the throttle it runs fine, when i'm coasting (foot off the throttle for awhile untill rpms go down) the car will die if i don't keep it my foot on the throttle, a side note it is a very cold day today so i'm not sure if its the dense air or it's something completely different. but it almost seems like it's not getting gas if i'm not mistaken. but again i'm a noob, any help would be greatly appreciated
zomblaya 3sgte celica problems Nov 25, 2013 - 2:52 PM
Box Could be the IACV is completely clogged or seized,... Nov 25, 2013 - 3:04 PM
match220 QUOTE (Box @ Nov 25, 2013 - 10:04 AM... Dec 15, 2013 - 7:06 AM
zomblaya Wow, thanks for the fast reply, should i clean it ... Nov 25, 2013 - 3:24 PM
Box $250 or $2,500!? Either way that... Nov 25, 2013 - 3:40 PM
zomblaya 250, a mother sold me her sons car because he had ... Nov 25, 2013 - 3:42 PM
cardshark525 QUOTE (zomblaya @ Nov 25, 2013 - 3:4... Nov 25, 2013 - 5:21 PM
Box You're extremely lucky, that is probably the d... Nov 25, 2013 - 3:45 PM
zomblaya QUOTE (Box @ Nov 25, 2013 - 3:45 PM)... Nov 25, 2013 - 7:05 PM
garin if you need an iac i can help you. pm me! Nov 25, 2013 - 6:53 PM
garin can you post a pic? gen i & ii used a toyota c... Nov 25, 2013 - 7:14 PM
zomblaya QUOTE (garin @ Nov 25, 2013 - 7:14 P... Nov 25, 2013 - 7:24 PM
zomblaya RE: 3sgte celica problems Nov 26, 2013 - 1:26 PM
Box Looks to be a second gen from a MR2. Nov 26, 2013 - 1:49 PM
zomblaya Ah okay, i'm new to celica's so i wouldn... Nov 26, 2013 - 1:52 PM
Box It's better than what it came from the factory... Nov 26, 2013 - 2:12 PM
zomblaya Alright.. So next step would be to find a leak? An... Nov 26, 2013 - 2:16 PM
Box A leak would cause idle to be high and not drop, y... Nov 26, 2013 - 2:23 PM
zomblaya Does this help? Nov 26, 2013 - 2:34 PM
Box The IACV is what's at the bottom with the thre... Nov 26, 2013 - 2:44 PM
zomblaya i tried taking a picture of under my TB Nov 26, 2013 - 2:56 PM
Box Hard to tell, but it looks like it's not even ... Nov 26, 2013 - 3:05 PM
zomblaya Alright, thanks box for your help! It's go... Nov 26, 2013 - 3:08 PM
Box Not a problem. For the time being what you could ... Nov 26, 2013 - 3:49 PM
zomblaya You wouldn't by chance have a guide for that w... Nov 26, 2013 - 3:51 PM
Box Probably the easiest way would be to tighten the t... Nov 26, 2013 - 4:08 PM
garin like i said before i have a few iac's laying a... Nov 26, 2013 - 6:19 PM
zomblaya QUOTE (garin @ Nov 26, 2013 - 7:19 P... Nov 26, 2013 - 6:32 PM
garin QUOTE (zomblaya @ Nov 26, 2013 - 6:3... Nov 27, 2013 - 6:59 AM
toy8490 try adjusting base idle with the idle screw Dec 6, 2013 - 11:14 AM
lagos QUOTE (zomblaya @ Nov 25, 2013 - 2:5... Dec 6, 2013 - 3:27 PM
zomblaya (if my post shows up, which i kind of doubt becaus... Dec 6, 2013 - 8:25 PM
zomblaya Alright so a little bit of an update, my car does ... Dec 7, 2013 - 9:13 AM
Box I said at least in some time. Dec 16, 2013 - 12:35 AM![]() ![]() |
| Lo-Fi Version | Time is now: June 21st, 2026 - 7:07 AM |
